Help, missfire between 2500-4000 WTF!!!!!
Old 05-01-2006, 09:33 PM
sipofa's Avatar
Default Help, missfire between 2500-4000 WTF!!!!!
Hey guys, I got a SS that has been misfiring since I got it. Got a new driver side cat and rear sensor and still same problem, when you open it up engine light comes on, but it misfires all the time between 25-4000rpm. When engine light comes on code is always the same. As long as you drive easy the engine light does not come on. Any ideas???? Thanks.
Old 05-01-2006, 10:07 PM
calongo_SS's Avatar
plugs, wires, fuel filter, dirty/weak injector, vacuum leak.... that should get you started.
Have you scanned it? What code? multiple cylinders or just one?
Old 05-01-2006, 11:02 PM
sleepersilverado's Avatar
what all is done to the car?
Old 05-02-2006, 07:27 AM
sipofa's Avatar
Hello, new wires, plugs, fuel filter, rh cat and rear o2 sensor, under hard accelleration it misses, if I roll on it usually takes the gas ok??? All car has is a LID and Flowmaster cat back. Thanks.
Old 05-02-2006, 07:30 AM
Michael02hawk's Avatar
It could simply need a crank re-learn.
Old 05-04-2006, 07:12 AM
sipofa's Avatar
hello guys, I unplug my MAF and no more hesitation????
Old 05-04-2006, 11:09 AM
calongo_SS's Avatar
Try cleaning it with some electrical contact cleaner and then put if back.
Old 05-04-2006, 08:31 PM
sipofa's Avatar
Hello, yeah that is what I am trying now. hope it works.
