How many pounds of boost on stock ls1
I am gonna run a rear mount turbo on my 98 ls1 u guys think i can run 8 pounds. Also what kind of power can i make with 8 pounds, its a stock bottom end. thanks
I am not sure if there is any differance between super and turbo when it comes to the amount of boost you can load into the top of a stock ls1. But if it helps i am running a procharged 8 psi of boost in my 04 gto and the key to going up to 8 as opposed to 6 or 7 psi was the exhaust. procharger doesnt recomend going that high unless you have headers and an exhaust the pressure has to go somewhere after combustion is achieved. As far as power is concerned I was dynojet tuned at 497hp at the rear. Boost is the way to go bro
11 was the lowest mine went, i was often at 15 psi and sometimes 16 psi. Finally lost the motor due to rod bolt stretch after 15k miles and a 6700 rpm limiter on a 2000 shortblock. Not a bad failure, just started ticking from rod knock.
Longevity of the motor is based on the tune and knowledge of the end user. Stock parts are plenty strong.
