How many pounds of boost on stock ls1
Old May 2, 2006 | 07:14 PM
BumbyHoodTA's Avatar
Default How many pounds of boost on stock ls1
I am gonna run a rear mount turbo on my 98 ls1 u guys think i can run 8 pounds. Also what kind of power can i make with 8 pounds, its a stock bottom end. thanks
Old May 2, 2006 | 07:18 PM
KAOS's Avatar
10 took mine out
Old May 2, 2006 | 07:27 PM
brian28kgto's Avatar
I am not sure if there is any differance between super and turbo when it comes to the amount of boost you can load into the top of a stock ls1. But if it helps i am running a procharged 8 psi of boost in my 04 gto and the key to going up to 8 as opposed to 6 or 7 psi was the exhaust. procharger doesnt recomend going that high unless you have headers and an exhaust the pressure has to go somewhere after combustion is achieved. As far as power is concerned I was dynojet tuned at 497hp at the rear. Boost is the way to go bro
Old May 2, 2006 | 08:08 PM
Boo"SS"t's Avatar
.........@ 10#'s
Old May 2, 2006 | 08:11 PM
bboyferal's Avatar
Boost is GOOD.
Old May 2, 2006 | 08:17 PM
Boo"SS"t's Avatar
It sure is. It's soooo addicting!
Old May 2, 2006 | 09:10 PM
1320's Avatar
I run 13-14 on mine with a gt76.
Old May 2, 2006 | 09:12 PM
bboyferal's Avatar
.... Brave man...
Old May 2, 2006 | 09:36 PM
1320's Avatar
6 months, 91 octane.....careful tuning.........water/meth........fmic........arp studs......
Old May 2, 2006 | 09:51 PM
chriswtx's Avatar
10psi here going good but have it pig rich to keep it safe
Old May 3, 2006 | 12:59 AM
Zombie's Avatar
11 was the lowest mine went, i was often at 15 psi and sometimes 16 psi. Finally lost the motor due to rod bolt stretch after 15k miles and a 6700 rpm limiter on a 2000 shortblock. Not a bad failure, just started ticking from rod knock.
Longevity of the motor is based on the tune and knowledge of the end user. Stock parts are plenty strong.
Old May 3, 2006 | 01:38 AM
1BDWS6's Avatar
A buddy of mine's car (Red91Z) made 518rwhp on 10psi with 100% stock longblock. Car was in Chevy High for a couple of months for an STS turbo install...
Old May 3, 2006 | 10:34 PM
Drewstein's Avatar
10psi here. I only run 10degrees of timing above 6K rpm for safety. If I had the stones, my numbers could be higher.
Old May 3, 2006 | 11:28 PM
LSs1Power's Avatar
13-15psi here no problems soo far
Old May 3, 2006 | 11:38 PM
Frost's Avatar
What's it feel like when hits 6K? Just quits pulling (comparatively speaking)?
Old May 4, 2006 | 02:07 AM
OldBlue's Avatar
I say 25.....
Old May 4, 2006 | 09:24 AM
bboyferal's Avatar
This thread or a tennis ball factory?
I don't know which one has more...
