What do I need to go with cam?
I have a buddy that just purchased stg 3 patriot ls6 heads and a comp cam extreme energy cam specs :605 609 lift 238 248 duration 112 lsa
what other parts will he need, ie. push rods, springs, etc.....if you could give part numbers too that would be greate
thanks
p.s. need to know everything needed to do proper install
thanks
Dual valve springs, retainers, hardened pushrods, new lifters, new timing chain, new oil pump.
Not everything is needed but is a good idea to replace while you are in there doing it.
What year is the car? If it has alot of miles on it he might want to look into a newer and heavier duty timing chain and a ported LS6 pump. We sell the PRC dual valve spring kit that comes with titanium retainers, hardened seats and new valve seals that will work great with the cam he chose. He will also need hardened pushrods and a gasket kit. Let me know if you have any questions, we have everything in stock!
Zach
Zach
