2bar map sensor install and ?'sss
well I somehow found a way to get the sensor changed w/out taking the manifold off, quite simple now that I know how, though my wrists hurt like heck, haha... well I changed the map sensor but havent loaded the 2bar hptuners file yet, still stock, I'm wondering if just that sensor will screw w/things if I dont have time to load the new program before tomorrow..?..
wtf, this thread is old, now I'm getting replies, weird.... yeah so just changing the sensor messes things up, I was able to change the map w/out taking the manifold off, thank you y-body... I've had my 2bar sd tune going for a while now, its the best for tuning boosted engines.. check hptuners for more info, just cost extra $$ you didnt expect/want to spend but thats how everything goes right..
Originally Posted by blackbird345
Mecham can you give us some more info on running the 2 bar sensor?
all i did was just put it in...im using the cobalt 2bar sensor.
here is what my scanner logs look like with it
http://flowerstechnology.net/Documents/1st.xls
the reason i didnt convert to the 2bar is because after i only put in the MAP just like the help file says...my ltrims change from slightly positive at idle to like -10.9 at idle...the car leaves black soot on the ground and runs like crap. this is leaving my PE vs RPM the same and having the PE vs BOOST at 1.00
i wont do the 2bar tune until i get my fuel pressure taken care of and my tuner has time. so im using his last tune with the sensor...no problems
also...does every1 else MAP settings underboost fluctuate like mine do?..u can see it peak...go down a little..back up or does every1 elses go to peak and hold that number??
