blower brackets??
blower brackets??
i have 02 camaro, i am going to be running a d-1sc with double digit boost numbers. every thing i have been reading says i need to invest in a beefy blower mounting bracket. Does any body know where or who to talk to about getting one? i dont have many sources!!!!! thanks Josh b
TECH Cry Baby BOSS APPROVED!
Are you talking about the SDCE spring tensioner or the true tech steel bracket? I run both and they get the job done.
http://www.sd-concepts.com/cart/inde...products_id=19
http://truetechperformance.com/page/...rformance.html
We have used the stock ProCharger bracket assembly at 14 to 16 psi of boost without seeing slippage when we ditch the inlet hat from the ProCharger assembly, and use an aluminum 4.00" elbow and a larger air filter. The stock inlet hat is a big restriction on the LS1 F Body cars. Bob
Originally Posted by SVC707
ill be getting this aluminum elbow and larger air filter with the kit i ordered correct. i was concerned about if i have to get new brackets too.
