Any Guesses On Power And Tq?
went from a stock 98 cam to a lpe gt-7. running single truck manifold kit with t74 1.0 ar housing. on 10 psi i made 580 hp and 600tq on the last setup. then #7 piston broke. with 10 psi what do you think the tq will do? it shouldnt go down should it? looking to run 12 psi or so any thoughts on how she will do?
SPECS:w2w short block 9.27:1 comp., stage one prc 6l heads, gt7 cam and all of the supporting valve train. take some guesses
so...from my understanding...
new engine...with lower compression
different cam
again 10psi dyno
then 12psi dyno
10psi should probably be close to the same. this is definitely a good test of cams.
12psi 635/660
different cam
again 10psi dyno
then 12psi dyno
12psi 635/660
yeah they were bone stock. i bought a new set off of tsp. wont be dynoing till i get it back together, hopefully next weekend. right now dont have the funds to do any thing else. wife cut me off on the cash till i get a card paid off. on stock rails and lines, how far should i push it?
