I think I found the perfect rims for my Z, maybe...
Old 05-10-2006, 09:09 PM
Asmodeus's Avatar
Default I think I found the perfect rims for my Z, maybe...
http://www.centerlinewheels.com/whee..._id=2&sw_id=22
I am in love with these. Going by the "Does this fit" sticky, I have estimated that the 17x9.5's will fit on the rear with the 7" backspacing.. but.. I seem the need a 1/2 inch more backspacing on either the 17x7 or 17x8's for the front? Are my calculations WAY off? (these are offered in max 5" and 5.5" backspacing) Am I stuck putting 17x9.5's up front too?
I really really tried the sticky, even used a mm to inch conversion chart I found online (says 38mm = 1.5 inch and 56mm = 2.2 inch) but I'm not sure if it will work. I'm such a newb at this stuff
Old 05-11-2006, 12:06 AM
SSilverSSurfer's Avatar
those look nice...what color car?
Old 05-11-2006, 12:22 AM
Bad Blu Formula's Avatar
i think i've seen those on a bagged truck...
Old 05-11-2006, 12:38 AM
kornfreak_401's Avatar
i like
Old 05-11-2006, 01:34 AM
Moderator
nhra-trans-am's Avatar
those do look pretty cool, definately different.
Old 05-11-2006, 02:02 AM
skatinjay27's Avatar
boooo imo those will look like *** on a f-body
Old 05-11-2006, 02:11 AM
SLP LS1's Avatar
look good
Old 05-11-2006, 10:06 AM
RollTideTA's Avatar
Backspacing isn't as cut and dry as offset. So its hard to say that 7 is perfect, but its really close. I really think 17x9.5 all the way around would be the simplest if you ask me... You could even rotate your tires for better wear.
Old 05-11-2006, 06:15 PM
Asmodeus's Avatar
thanks I'll probably go with the 17x9.5's all around then. The car is Black, whisper mod headlights, ash tint all around. Was thinking about replacing the black Z28 fender badges with the '69 camaro fender badges. I'm about to install a head/cam kit so the point about rotating tires is well taken. I guess I could live with a little more rolling resistance if I have to.
Old 05-11-2006, 06:40 PM
FLAWLS1T/A's Avatar
looks GOoood
Old 05-11-2006, 10:08 PM
'00_Z's Avatar
I checked these out a while back but they're pretty damn expensive. They are pretty sweet though.
