MS3 and boost?
MS3 and boost?
Just wondering if anyone could tell me how the magic stick cam will perform under boost? its the 113lsa, i already have this cam and love it N/A but want the most out of my future turbo setup (sts 10psi) thanks...
negative they are different...with a turbo cam you want the right abount of overlap so that you dont bleed off too much boost but at the same time spool the turbo fast. I personaly don't know much about it but you can check out some info about turbo cams at
http://www.forcedinductions.com/help.htm
down near the bottom there is info on turbo cams
