crank bolt
Old 05-19-2006, 07:27 PM
Temple, TX Resident
SiRgReg23's Avatar
Default crank bolt
can someone help me get the right longer crank bolt ........ no one around here has it ... checked napa... vato zone... advance.... even bolt stores ..... im kinda desperate ..
Old 05-19-2006, 07:45 PM
Bigdeezs's Avatar
Thunder has this part # for the crank bolt.Dont know if the longer one. Sound like a stock replacement bolt to me. Good luck.
12557840
Old 05-19-2006, 08:27 PM
Big Budda's Avatar
threaded rod and nut is the only way to go trust me....
m16x2
You can get it at
www.mcmastercarr.com
Old 05-19-2006, 08:56 PM
Temple, TX Resident
SiRgReg23's Avatar
how long does it need to be
Old 05-19-2006, 09:09 PM
makWS6's Avatar
I bought mine from True Value for $4. Its M16x2.0 pitch and 120mm long grade 8(approx. 1inch longer). Works great! Dont forget about a grade 8 washer too.
Old 05-19-2006, 09:27 PM
Temple, TX Resident
SiRgReg23's Avatar
did u use the longer one to take the pulley off too
Old 05-19-2006, 09:33 PM
CR00SS's Avatar
I cut my old bolt between the shoulder and threads then added 3/4 of an inch of solid mild steel rod rod same diameter as smooth section. I then gouged and welded the two ends together. I put the bolt in between two wood blocks in a vice got the torque to 200 foot pounds to make sure it wouldn`t break when pulling the pulley up. Once I got the pulley pulled almost all the the way up I then put my new bolt in and got my bolt to 200ft lbs. , but you`re supposed to get it up to 240 but at 200 it seemed like something may snap at any moment so I settled for 200. Its been doing good for a month now.
Old 05-19-2006, 10:04 PM
Temple, TX Resident
SiRgReg23's Avatar
will this work part number 95430A478 at http://www.mcmaster.com/ and would i need the fully threaded or the partially
