Oval exhaust, true duals. Anyone try this yet?
Old 01-09-2003, 10:12 AM
Black Sunshine/ 00SS's Avatar
Default Oval exhaust, true duals. Anyone try this yet?
I'd like to see some pics. I have been thinking about this for over a year now. If I knew how to weld, I would have done it already.
I'm thinking that because of the clearance issue on our cars (mine is lowered), that the duals would be the way to go. I have scrapes on my X-pipe and in various spots on my true duals. I would like to eliminate this. I'm thinking of a pipe that is no more than 2", but in oval & flows the eqv. of a 3" pipe.
Please direct me to some metal fabricating sites that will educate me on metal fab. I'm gonna learn how to weld this year. Thanks.
Old 01-09-2003, 05:45 PM
Fulton 1's Avatar
Default Re: Oval exhaust, true duals. Anyone try this yet?
Its a great idea and I too would love to see someone do it. I can't help with the welding, but here are a couple links for the oval tubing that might be of interest.
http://www.burnsstainless.com/OvalTu...valtubing.html
http://www.drgas.com/hooters-cat.html
Old 01-09-2003, 05:48 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,221 Likes on 778 Posts
LS1Tech 10 Year
Shorter answer is that nobody is running it unless they have the Spintech oval tubing... problem has been that you need buy their oval-to-round and round-to-oval transition pieces too and nobody has wanted to spend several hundos just on tubing, including a $200 x-pipe piece.
I have 'ovalized' 3" pipe, it was ovalized by Billingsley Racing a few years ago... I think that 2" height oval could work really well. For dual exhaust ideas check out www.ls1speed.com 's shop car...
Old 01-09-2003, 06:44 PM
What I thought of was starting with mandrel bends, getting the shape that I need with a 2" pipe. Then using a plazma cutter to slit cut it down the center. Use nails tack welded the propper distance apart, just to hold the shape, while it is held over flat metal, traced out, and then welded in. I would need the oval to round, but there is a metal fab place near here that I am sure can make those up for me, cheap. They mostly do heating ducts, but they work with heavier metals also, and this is simply oval ducting. Looks like I'm gonna be on my own for this one.
Old 01-09-2003, 09:00 PM
M3EATER's Avatar
I'm thinking about doing some prototyping on this general idea (using oval tube).
I'll let Y'all know as it progresses.
Gordon
www.provenperformanceconcepts.com
<img src="http://www.provenperformanceconcepts.com/PPC%20BANNER%20468x60.jpg" alt=" - " />
Old 01-10-2003, 01:01 AM
DARK AGE 53's Avatar
Black Sunshine/ 00SS, is the fab shop in the Owosso area?
Al
Old 01-10-2003, 09:16 AM
Moderator
jimmyblue's Avatar
Slit, and weld like 50-100 linear feet
(4 passes per pipe, 2 pipes, 10 feet per
side)? Sounds like insanity to me. Much
better to find someone who can roll a
couple of flats onto some 3", then you
only have to screw with the joints.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Black Sunshine/ 00SS:
<strong> What I thought of was starting with mandrel bends, getting the shape that I need with a 2" pipe. Then using a plazma cutter to slit cut it down the center. Use nails tack welded the propper distance apart, just to hold the shape, while it is held over flat metal, traced out, and then welded in. I would need the oval to round, but there is a metal fab place near here that I am sure can make those up for me, cheap. They mostly do heating ducts, but they work with heavier metals also, and this is simply oval ducting. Looks like I'm gonna be on my own for this one. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old 01-10-2003, 11:21 PM
Moderator
John B's Avatar
I just helped a friend of mine put an "X" pipe on his 3-1/2" ovalized exhaust on his 698RWHP N/A 542" C3. I'll see if I can get some pics...very trick!
Old 01-12-2003, 09:19 AM
Yes Al, it is in Owosso. Called Woodburys.
I'd like to see those pics John.
