Throttle body differences
Moderator
Re: Throttle body differences
Also differences in the coolant fittings
(early are same both sides, late are
fat, 90-degree on passenger and skinny,
straight on driver's side. And PCV breather
fitting was different on my '02 than the
early body I ported. PCV fitting is easy
to remove /swap, coolant is a bitch (can't
say impossible, but it felt more likely to
break than give, so I quit).
Casting #s are the same, it's just fittings
and shaft / spring that differ. If you're
going to bypass, then the rest of the
differences don't matter as everything else
will swap easily.
will swap easily.
