What heads 4 stroker
You want the most power huh...............LS7 with an LS7 intake. Or the 255cc ETs. Everything else is going to run a distant second. I wish I or anyone else for the matter could do an LSX casting to keep up with either, but it isnt going to happen. You wanna be the big dog, get either of those.
Brandon
Brandon
Brandon
Brandon
Originally Posted by jeremym
Thanks Man I called ET today and they said the 245cc would be perfect but I will check those out.
Brandon
would the fast 90/90 keep up w/ the ET's flow or would it choke it?
Brandon
You should run a big ported vic jr setup with 90mm or 105mm TB. That would be good for 20+ on top of the fast. If you do keep the fast, atleast get it ported.
Brandon
Brandon
Collections Hold
245 ls7
Actually for the best results, I would reccommend the etpls7 4"bore heads with the LS7 manifold kit. I have seen big power with this combo, not far off from the big dogg ls7
