tick tick tick.....solved
well my car started to tick and after searching i found that this problem was common with many ls1's. so i pulled the valve covers and all appeared to be normal. i checked the torque on the rocker arms and they were all fine. i was prepared to pull the heads and remove a bad lifter but when i pulled my push rods out i found one that was bent to ****. i'll post a pic later. so anybody else with the "ls1tick.com" problem check your push rods. later,matt.
