Need new short block advice
I recently found a crap load of metal shavings and chunks in my oil pan. I don't feel like trying to figure out the problem right now so I'm planning on ordering a new, forged short block. I have about $3600 and I'm not sure which direction to go to make the most out of my money. I'm hoping you guys (and gals) can give me some insight before I start calling the sponsors tomorrow.
The car right now has stock heads which were milled an unknown amount, full bolt-ons (minus EWP), G5X3, PP gold springs, Thunder pushrods, LS2 timing chain, 'King James' ported and shimmed (.060) oil pump, Midwest 4400 2.5 STR stall, mildly built trans, and 3.73 gears.
I just installed a shortblock from LME I needed a stock replacment that could handle a small shot of N20 safely.. they sold me the following
LME 347
Weiseco 3.905 pistons
CA Dura Moly Rings
Stock Rods and Crank
ARP rod bolts
Fedral Mogul Main Bearings
Clevite rod bearings
Dura Bond cam bearings
Balanced and blueprinted
Patriot Stage 3 heads 2.055/1.57 59CC (11.3:1 compression)
LME 347
CA Dura Moly Rings
ARP rod bolts
most of the sponsors shortblocks are around $2800 or so,then you will need new gaskets and head bolts or studs.now would be the perfect time if you could save alittle more to get a set of the budget 243s.
The car will more then likely get sprayed within the next year. For right now it is staying NA though.
I thought about trying to with a forged LS2 but I don't think that is going to fit into the budget.
