underdrive pulley's worth the$???
Old 05-31-2006, 05:59 PM
Mighty Whitey's Avatar
Default underdrive pulley's worth the$???
I know some say the $60 or $80 bucks for them is a waste of money. then others swear buy them.
who's right? and who's wrong? I'm working on every possible way for 400rwhp (far fetched... perhaps. impossible... no) and didn't know if they made any gain what so ever.
ALSO, should I buy the cheap ones that has the crank pulley that goes in behind the balancer and then put the balancer on after? or an "underdrive" balancer?
I know a boy with a '97 model T/A that put the cheap ones on, and FORGOT to put the balancer back on, needless to say the timing chain broke and bent a few valves, and wore the main bearings a little weird: all with 27k miles on the clock.
Old 05-31-2006, 06:06 PM
Honda Hunter's Avatar
I say not worth it.
Old 05-31-2006, 06:08 PM
96z28camaro's Avatar
i say go with the pulley. I bought mine from G2 motorsports so I don't know how the cheaper ones perform but i was fairly pleased with mine. I gained almost a tenth of a sec in my 1/8 from it. They only complaint i have is that my volts sits at about 12.5-12.7 when i am sitting at a stop light but once you give it any gas at all the volts are rigth back up to where they should be.
Old 05-31-2006, 06:09 PM
ss1129's Avatar
bahrain sucks monkey *****. You at the Navy Base?
Not worth it also.
Old 05-31-2006, 06:35 PM
Not worth it also.
LOL WTF. Yes I am.
Old 05-31-2006, 06:36 PM
ss1129's Avatar
I was there for 7 months back in 2002 for marcent.
Old 05-31-2006, 07:45 PM
Sick99WS6's Avatar
Not worth it. Pain of an install for a part that does nothing. Oh yeah, the $ thing too. If you get it for free, yeah go ahead and do it. Other mods to better spend money
Old 05-31-2006, 08:51 PM
94'BLKBRD's Avatar
not worth the money
Old 05-31-2006, 09:07 PM
Oh, ok. Ive been here since 04. I was also here in 98 on the Mine sweepers.
Old 05-31-2006, 09:16 PM
infinitebird's Avatar
If you want 400rwhp you're probably going to need a bigger cam than that one.
Old 05-31-2006, 09:45 PM
perhaps, but:
with my heads, a comp #501 cam (212/218) on 1.6's (.523/.528") and a 4L60E and a 3.23 gear with all the supporting intake/exhaust stuff. I made 352rwhp/371ft.lbs.
since then:
comp #503 cam, cloyes double roller (no water pump gear) CSR electric water pump, as well as a t56. I figure with less drivetrain loss with the 6spd, roller timing set, and no water pump drag, as well as the much needed breathing from the bigger cam, and a dyno tune? I may cut it close, 380rwhp is more believable, I know; but if there's just a few more things I could do to put it at the 400 mark would be great. damn, knew I shoulda done a 3-angle valve job!
Old 06-01-2006, 07:26 PM
1BadZ95's Avatar
I say get it. It may give you the 5hp you need. It all adds up.
Old 06-01-2006, 07:35 PM
Originally Posted by Mighty Whitey
perhaps, but:
since then:
the t56 and dyno tune will help a lot. Also get a cutout if you don't have one yet, probably at least another 5-10 there.
Old 06-01-2006, 10:06 PM
the_merv's Avatar
I have a 34% underdrive Crank Pulley, got it real cheap. The RPM's shoot up quicker than normal, and I have no problem with the Alternator.
Old 06-02-2006, 05:38 PM
I'd never heard of that being the case, but my buddy has a '97 z-28 with JUST the cheap bbk or march underdrive pulley (not balancer) and he swears and declares it rev's quicker, and many other people say his car does seem to rev quicker when you just 'blip' the throttle.
balancer or just pulley? which is better?
Old 06-02-2006, 05:53 PM
lt1zpwr's Avatar
id say go for it, i did but if u use your car as a daily driver u may wanna get a dual pulley kit, where u get crank and alternator pulleys. i got the march pullies the crank one only states like 15 hp and the dual pulley set is like 12 hp and its not really hard to install u just remove your belt and the 3 bolts from the hub put new pulley on then balancer and bolt up the 3 bolts u will also need a shorter belt
Old 06-02-2006, 11:26 PM
the_merv's Avatar
Well if I say it, and he says it Revs Quicker, and we both have them, there is one thing they do. Mine is the Pulley. Unbolted the balancer, bolted the Pulley between the Hub and the Balancer.
Old 06-03-2006, 01:27 AM
Gun5's Avatar
my engine is getting a complete rebuild... what should I do... get a $40 pulley or what guys???
Old 06-04-2006, 12:30 AM
97LT1WS6's Avatar
I like the pulleys, I noticed a quicker rev and i really helpsout when the a/c is on. A lot less drag on the engine. You can't even feel the compress kick on. It runs with the a/c on with the pullies like it did without the pullies and the a/c off. I also installed the smaller alternator pully to bring the volts back up to normal.
Old 06-04-2006, 04:31 AM
the_merv's Avatar
My Alternator has the stock one on it, but I have a Stripper, so the only thing that it runs really is the stock GM CD Player. I have the 140A high-output one, factory stock.
Quick Reply: underdrive pulley's worth the$???
