Since everyone is talking about MAFs...Fired up the custom 100mm maf
We've had a project on the back burner and since everyones talking about going back to the MAF we decided to throw on one we made a couple of months back. Its uses the factory electronics inside of a 100mm+ housing. Inital testing shows great response(throttle and tuning). I'll report back in a couple of hours!
Originally Posted by SmokingWS6
Sounds promising. Let us know how the results turn out. This would be great for FI applications.
Tim
going from the 75mm to the 85 mm you get a tad bit more room on the upper frequencies. if the 75mm reads 11000 hz the 85mm will now read 10500 or 10000 hz giving you just a tad bit more room
Coal Mining Director
Originally Posted by RedHardSupra
how is this gonna help the pcm limitation of max airflow in the maf calibration table?
It's not unless you try to half all the tables....which you could try with a stock maf but would be very time consuming.
Larger maf helps with pressure drop through the maf as the main benefit. If you're running high boost (+16psi), it could pick you up 1 - 2 psi.
