burning rubber smell
Old 06-05-2006, 03:27 AM
LS1Lust's Avatar
Default burning rubber smell
No it does not happen after a burn out It is not my tires.
After I backed out of my garage I could smell a burning rubber smell in the garage. I could smell it again tonight after I went WOT and pulled over and popped the hood. I can't figure out what it is. I know it is coming from the engine bay. And burning rubber is the only way I can think to describe it.
Let me know if you guys can think of anything or if you need any more info I left out.
Old 06-05-2006, 04:26 AM
1QUIKWS6's Avatar
Might be one of your two idler pulleys is seized and the belt is smokin'
Old 06-05-2006, 03:21 PM
LS1Lust's Avatar
I was thinking it might be the belt what is the best way to see if a pulley is seized?
Old 06-05-2006, 03:45 PM
1QUIKWS6's Avatar
Take the belt off and try to turn each pulley (except for the crank obviously )
The one that doesn't turn would be the bad one...
Don't forget you have a seperate belt for the A/C
-Jay-
Old 06-05-2006, 04:03 PM
todddchi's Avatar
I doubt it is a siezed pully, youd've figured that out by now. You might just have a belt slipping, but the troubleshooting process is the same. Check the pulleys for smooth free rotation, and check the belts for wear/glazing.
Belt dressing is a band-aid, but if the belts are cracked or glazed, get them changed out asap.
Old 06-05-2006, 04:08 PM
LS1Lust's Avatar
I have never taken the belt off bfore, what does it take to get it off and then to get it back on?
Old 06-06-2006, 02:52 PM
JOSE REBS's Avatar
take a peek under the car just for ***** and giggles to make sure you don't have a platic bag melted to your exhaust
Old 06-06-2006, 05:13 PM
stangeater99's Avatar
ur belt is probably old and lose and is slipping that would cause the burning odor. Or something might be rubbing on one of the pulleys
Old 06-06-2006, 05:40 PM
LS1Lust's Avatar
Well I got the belt off and all the pulleys turn freely and the belt is in good shape. All I can think of is it might be my clutch starting to go. I did some track passes with headers on the stock clutch. I am not sure if it could handle it. And the smell seems to really be there after going up my steep driveway or after a WOT run.
Old 06-07-2006, 06:26 AM
Charging TA's Avatar
I could see how burning clutch could be confused for burning rubber... Sounds like thats the problem now.
Old 06-07-2006, 09:19 AM
ls1_bc's Avatar
That would be my guess.
Old 06-07-2006, 10:09 PM
LS1Lust's Avatar
Yeah my mistake, but both me and my dad thought it smelled like rubber So it looks likes I will be getting a new clutch when this one dies.
Old 06-07-2006, 10:21 PM
bray's Avatar
you cant go wrong with a specIII
Old 06-07-2006, 10:35 PM
LS1Lust's Avatar
the clutch thing makes more and more sense the more I think about it. I dobut the stock clutch could handle the track with headers
