how often to replace springs?
Assuming my springs can handle my cam this whole year, I plan on buying a new set of springs every year or so...though who knows if I'll have the car long enough to change them more than once or twice. I'm running Patriot Gold dual springs on my .641/.646 lift cam with LSK lobes.
Patriot golds have higher open and seat pressures than the 918s, making the material more brittle and wears out faster. Not to mention the much higher lift .646" lift and and valve speed due to the high ramp rates of the LSK lobes (very aggressive).
Its not a terrible job, and I think the springs themselves are only like $150-160 tops since I already have everything else (retainers, seats, locks, etc.)
I replaced mine at 1500 and the second set broke at 900. Track use only. Now going with comp 921 instead of Manley single. Rev limiter is set at 6700. Car is usually in the upper power band at the track and a gear lower in the turns than all ther cars.
