Do you really have to take out the plugs?
When changing valve springs? I am going to do a cam swap sometime in the future but would like to go ahead and do the springs/pushrods myself so I don't waste the time of my helpers.
TIA
Brian
TIA
Brian
TIA
Brian
TIA
Brian
Originally Posted by MrDude_1
how are you planning on holding the valve up for the spring change?
normally i take them out, not because i want to, but because i have to remove them to connect the airline.
not meaning to hijack the thread, but what exactly is TDC, top dead center?
Also, what does the plugs have to do with this...do you look into the hole with amirror or something to see if the piston is as high as it can go?? is that what this whoe TDC process is?
THANKS
THANKS
Originally Posted by GuitsBoy
TDC method. Ive heard too many stories about people dropping valves down because the valve compressor pushed on the stem using the air method.
on the LS1s, the valve hits the cyl wall before it can fall all the way out.... then you just roatate the motor by hand....but i havent dropped one yet using air..
THANKS
THANKS
If youve got the timing cover off you can find TDC when the timing dots are facing eachother. If the cover is on, then you need to pull the #1 plug and feel for TDC with a straw or pencil or something.
The ls1howto.com guide calls for you to take the plugs out, but its not necessary if youre gonna use the TDC method, and odnt mind going a little slower waiting for compression to bleed off.
TDC does indeed mean Top Dead Center, the point at which the piston is at the top of the bore. This will hold up the valves so they dont fall down into the cylinder bore when theyre no long held up by the springs.
I think I know what youre saying....dont you need to know the firing order of the pistons to determine which piston is at TDC after each revolution of teh timing gears?
THANKS MAN!!
hmm I see, can you be a little more specific on the whole timing dot thing....
THANKS MAN!!
THANKS MAN!!
THANKS MAN!!
THANKS MAN!!
http://www.ls1howto.com/index.php?article=23
