For those that have relocated coil packs, i have a ?
Old 03-10-2003, 11:42 PM
ArcticSS's Avatar
Default For those that have relocated coil packs, i have a ?
What kind of wires did ya'll use for this? Do i have to get some specific ones or what? im not sure how to approach this. thanks <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old 03-11-2003, 07:34 AM
GeorgeC's Avatar
Default Re: For those that have relocated coil packs, i have a ?
Universal cut-to-fit wires w/180 degree plug boots, and LT1 optispark boots (to fit the coil end).
I have Taylor 8mm wires on mine...
Old 03-11-2003, 05:24 PM
theblur98ss's Avatar
Any part #'s for the terminals/boots for the coil end?
Old 03-11-2003, 06:32 PM
Durs96TA's Avatar
The coil relocation packs from Jay Fisher come with wires. I have seen this kit in person on a few cars and it is awesome.
Old 03-11-2003, 07:01 PM
Quick98SS's Avatar
Where can i get the kit?
Old 03-11-2003, 09:13 PM
GeorgeC's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by theblur98ss:
<strong> Any part #'s for the terminals/boots for the coil end? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Nope, not right off hand... If you call Thunder Racing, Paul can set you up with what you need.
He got my stuff to me in no time flat!
Old 03-11-2003, 10:33 PM
The Bull
DERTY's Avatar
If you know what length wires you need you can call up Moroso and they will custom cut some wires for you for 100 bucks. It takes two weeks to get them, and yes they are the Ultra 40 race wires.
Old 03-11-2003, 10:54 PM
I have a set of universal wires but just need the ends. Could I steal a set from my stock plugs and recrimp them?
Old 03-12-2003, 06:40 PM
Quick98SS's Avatar
where can i get a relocation kit?
Thanks
Old 03-14-2003, 03:57 AM
Rob Mattingly's Avatar
TTT and does anybody have pics of the relocated packs? Anyone make a kit? I would like to do this but dont know where to start
Old 03-14-2003, 06:07 PM
Roadrunner 45's Avatar
Summit sells a universal, trim to fit, 8mm wire kit that comes with a crimping tool. The set I used was SUM-G826 it was $31.95. As others have mentioned, you'll also need to order optispark terminals- I got a taylor set from Summit also (not listed in their catalog, but they DO carry them). As far as the bracketry is concerned there's a step by step how to on that other site (ls1info.com). You won't have any problems provided you don't mind doing a little fabrication (this is more rewarding than buying a kit any day), have a drill, and a bench vise to bend the brackets(a bench brake is ideal but most won't have one). Keep in mind that you can pretty much put the coils wherever you want to provided that they're not subject to excessive vibration, moisture, or heat.
