MS4 and dual spring maintenence
Originally Posted by CraZee ZO6
Somone who is running tsp's MS4 cam package, how often should they change the dual springs? 20k?
If you want you could always do them as part of a service at a set interval, but I don't really think you state that it must be this milage or else kind of thing.
If you beat on the car all the time in the high rpms and/or use a decent shot of nitrous the wear is going to be increased. If you spend 80%+ of those 20k miles babying it in town or at 50mph on the freeway then they will last a lot longer.
The springs should last quite a while guys. If you are concerned with wear, pull a couple off at 10k and have the pressures checked and see where they are. I have run them in my car with a .646" lift cam for 15k along with a 300 shot and they are perfect! I don't think you will have any issues with them.
Chris
