Tuning for corn gas?
Old 06-28-2006, 01:38 PM
robertbartsch's Avatar
Default Tuning for corn gas?
Any thoughts on this? My car hates the stuff!
Old 06-28-2006, 01:59 PM
horist's Avatar
standard VE tuning... correct your fuel trims...
10% ethanol decreases the overall efficiency of gasoline slightly (~3-4% maybe)
Though shouldn't take much tuning if any unless your fuel trims are all over the place ... the midwest has used the 10% ethanol blend for as long as I can remember... and my car's never had a problem running on it ...
Even w/the current mods, didn't take a whole lot of time tuning (and that was more so because of the large cam and converter than the gas)
Old 06-28-2006, 02:32 PM
Runn's Avatar
My car loves the stuff
I´m running 100% E85 and the car feels alot stronger.
Old 06-29-2006, 09:35 AM
Maybe it is the NY corn is not as good as the stuff grown out west or in Sveeeeden? We use genetically modified corn in our NY petrol (gas). The "moded" genes must be junk, however!
Is Uncle Sam still subsidizing the corn farmers? This is bull. Let's subsidize Exxon too - they only made $9 BILLION USD after tax last quarter.
Old 06-29-2006, 12:12 PM
ZL1Killa's Avatar
what did you have to change on your car?
are you talking about the actual E85 which is only 15% gasoline? don't you have to do more than just tune for that?
Old 06-29-2006, 01:44 PM
SSpdDmon's Avatar
I was under the impression you need a certain kind of tank, fuel lines, pump and injectors to run the corn gas...not to mention you get 25-35% less economy out of Ethanol since it doesn't produce the kind of energy regular gasoline does. I fill up 12 times/month as it is. 3 more $25 trips to the gas pump hardly seems more economical to me. I know GM doesn't list our cars under there fleet of FlexFuel vehicles. I wouldn't run more than a 10% blend unless you are 100% sure it's ok to run that way...just my $0.02.
Old 06-29-2006, 02:55 PM
SmokingWS6's Avatar
Correct. If you run E85 on a stock ls1 you will have problems.
Old 06-29-2006, 03:11 PM
MrDude_1's Avatar
i had to add about 7% across the board when they switched gas here...
Old 06-29-2006, 03:59 PM
ZL1Killa's Avatar
so what in the hell did you do to your car?
Old 06-29-2006, 08:05 PM
SSpdDmon's Avatar
I hope this is his way of being sarchastic (unless he completely modified his fuel system).
Old 06-30-2006, 08:22 AM
MrDude_1's Avatar
no, hes in sweden, and he modded his car to run on the stuff.. its not hard. your tank and fuel lines are compatible plastic.. injector Orings arnt a problem... the largest hurdle is the fact that you have to supply alot more fuel..
but this is off topic.. i think the topic starter was refering to the 10% ethnol they blend into standard gasoline now... if you want to know more about Runn's conversion, search under his name.. if i recall, he posted a good bit up about it.
Old 07-01-2006, 03:37 PM
Runn's Avatar
No...
If you dont trust me check the differences betwen the 5.3 flexi and the 5.7 LS1. You will be surprised. Of course you have to make alot of tuning to get the car to run good. And bigger injectors....
Search a little...
Old 07-01-2006, 10:18 PM
ZL1Killa's Avatar
thanks
Old 07-01-2006, 11:00 PM
SSpdDmon's Avatar
No...
Search a little...
If you still run that gas in a year or two, post up and tell us how your seals are holding up.
Old 07-02-2006, 12:55 AM
camrsz's Avatar
I use e 85 in my ls1 73 camaro. I have an all alcohol compatible fuel system. The car does feel more powerfull tuned on e 85. Another thing I noticed is the engine temps run about 20* cooler.
Old 07-02-2006, 08:35 AM
ZL1Killa's Avatar
they would run cooler because it doesn't burn as hot
Old 07-02-2006, 09:48 AM
TunedPower's Avatar
Correct. I think it'd be tough to find many stations with 10% ethanol, much less the E85 stations.
Old 07-06-2006, 10:21 AM
Rabidbandit's Avatar
10% is going to be everywhere....what do you think replaced all that MTBE the EPA was screaming about Ethanol is offically the new octane booster for gasoline. I ticks me off that they say it's more difficult to blend ethanol into gasoline...their just looking for ways to jack up the damn price. The midwest has been using it for years...93 was the same price as 87 for the last 8 years in my town. Everybody's worried about the drop in fuel economy with E85...we have it all over Nebraska. My Pop's new Chevy with the L59 5.3 loves it after he threw a MagnaCharger on it. Gets about 18-20mpg Hwy...unloaded of coarse. It's a Ext. cab short box 4x4...incase you where wondering. I'd think as long as you have high compression or some type of forced induction...you can do better with E85. If they have variable compression engines that switch from like 9:1 thru 12.5:1...you would probably see no drop in performance! Ofcoarse...if they decide to produce something like that. Anyway that's my take on it
Old 07-06-2006, 12:57 PM
MrDude_1's Avatar
yup.
the sunoco across the street from me switched to it while i was running a SD openloop tune... i ended up redoing most of my VE table about 7% according to my wideband.
i can now tell who uses what by reading the wideband... if im a little on the fat side, its more MTBE type fuel.. if im a little leaner or dead on, im on the 10% blend stuff...
but for the most part, i fillup at the same sunoco.... because its across the street from me.
Old 07-06-2006, 02:28 PM
Did ya have to mess with the timing tables switching over... had to up the value some...VE adj. only about 4% here. Not as critical as your setup with the SD...but I want every last drop out of this thing. I'm also looking to add two cylinders to my ride in the future...let me know how your S10 swap turns out I have a brand new 350 Dart block sitting in plastic in storage...just haven't thrown the guts in yet. Your goin' with a genIII but I think I'm going to stay GenI...a little more budget. Damn Dart block is the most expensive part of the combo. For the price I payed for it you'd be jealous
