C6 Track numbers
C6 Track numbers
My last run of the night was my best.
60'---1.751
1/8--7.778
mph--91.93
1/4---12.01
mph--116.00
My best mph of the night was 116.96
I all I got 10 passes in tonight 5---12.0's,3--12.1's,1---12.24, 1----12.44
The majority of my 60's were 1.7's and low 1.8's
60'---1.751
1/8--7.778
mph--91.93
1/4---12.01
mph--116.00
Originally Posted by Nine Ball
Nice results! Be careful with that rearend, they break pretty easily at the track
Running et street?? or would it be ok for DR's or stock tires?
9 Sec. Club!!!
Dan
Originally Posted by dan03mach
Any 17" tire is going to shock the rear alot more then a 15 or 16" tire would. I broke a few differentials running 17" ET Streets, since I went with the 15" non at all. The ET streets flex more and give a little bit more cushion then a Drag radial would so it doesn't shock the rear as hard. I would pull back on the clutch a little right before you start to launch the car to give it a little drive train preload, this will help save the rear.. If you just dump the clutch and shock the rear you are looking at breaking it.. I also think you can run a faster ET with the mph and 60fts your pulling.. If you preload the rear like I said you should get some better 60fts and lower ETs.. I hope I can help, I have been doing that for some time now and my 60's have drop alot and the ET's are getting lower..
Dan
Dan
oh and those are some good passes, i have run 12 in one night before but that was on 1/8 mile.
9 Sec. Club!!!
Originally Posted by Ramshaft
but if you let out on the clutch are you not going to roll throught the light. sorry for the dumb question but i have having a really hard time breaking the 2.xx 60' and i an looking for any help i can get.
