Track results... More tuning needed :(
Old 07-01-2006, 01:04 AM
Linxs's Avatar
Default Track results... More tuning needed :(
I ran 5 times. I was getting a good deal of KR 1/2 way down the track so
I turned down the PSI a couple of times. Looks like I need some more tuning
60ft.....2.520
1/8......9.178
MPH.....85.73
1/4......13.683
MPH.....106
60ft.....2.403
1/8......9.066
MPH.....85.03
1/4......13.640
MPH.....108.45
60ft.....2.380
1/8......8.975
MPH.....85.32
1/4......13.465
MPH.....109.26
60ft.....2.297
1/8......8.959
MPH.....85.85
1/4......13.514
MPH.....105.14
And the very last run.... best of the night I'll post a video once it's done....
60ft.....2.168
1/8......8.637
MPH.....86.23
1/4......13.095
MPH.....109.42
Old 07-01-2006, 01:15 AM
| Powered by Satan |'s Avatar
damn, hope you get the bugs worked out... was this on pump or did you slap race in the tank?
Old 07-01-2006, 01:19 AM
Sprayed1998's Avatar
I was there to 12.30's@116+, horrible air. I aint going back till winter, I got ate alive by mesquitos too. But I did beat up on that red Mach 1 with the kenny bell on I10 going home.
Old 07-01-2006, 02:03 AM
MAXIMO's Avatar
Something is wrong i think. You have some DR's or street tires? I ran the 1/8 miles faster and with a broken tranny. You should launch a little harder I ended up getting my 60 ft to 1.9's with a 3500 launch. Keep up the tunning. Lower the tire pressure.
Old 07-01-2006, 08:01 AM
nasty_00_ss's Avatar
almost to the 12's - - i tried looking for your car last night but didnt see you -- we had mr. whittmans coupe out there.
Old 07-01-2006, 08:56 AM
Linxs's Avatar
This was on street tires and pump gas. I'll look at the logs today and see what needs to be changed.
BTW this was in a V6. I really wanted mid 12's. O well, here's the video.
In the first one I got rapped by a GN. The second run was the run of the night....
http://video.ls1tech.com/video/bd9c0...b8af6affee.htm
Old 07-01-2006, 09:07 AM
jmorgan's Avatar
video is messed up
Old 07-01-2006, 09:54 AM
only shows us u sitting in the staging lane...... see u monday
Old 07-01-2006, 10:29 AM
Linxs's Avatar
Originally Posted by jmorgan
video is messed up
well crap, it only took the first chapter....
Old 07-01-2006, 10:59 AM
WildBills Toyota's Avatar
dude, get you ls6 and pulley and it will be as fast as my ws6 was!!! Thats pimp
Old 07-01-2006, 01:05 PM
I think in winter I could break 11's, but I need to practice my driving. 2.0+ 60fts were not cutting it at all. My dumbass cut a 1.93 on my last run and missed 2nd gear, wtf is that! Ill go back in winter time and try again. BTW, I saw that turvo V6 and his main problem was traction, I think if he was on some drags he would be a legit mid 12 second car, but I did think the mph was a bit low for a 400rwhp car.
Old 07-01-2006, 01:44 PM
-PEPE-'s Avatar
Good luck getting the wrinkles ironed out, heard the track sucked last night.
Old 07-01-2006, 01:53 PM
it did
Old 07-01-2006, 02:04 PM
-PEPE-'s Avatar
it did
yeah but at least you cracked a Mach1 ..budy of mine has a Mach, those cars are very responsive to mild mods, he hasn't tapped into engine work yet but is running low 12s with boltons and mild tuning.
Old 07-01-2006, 02:24 PM
Linxs's Avatar
Tuning through 2nd gear was good. Once I got into 3rd I started getting some KR and once I hit 4th I got even more. I just need some more tuning and I lowered the boost to try an get ride of it. The new cam obviously messed up the tune I had.
Old 07-01-2006, 02:44 PM
This was one **** poor running mach, I mean even with a KB he was getting WALKED on I10, it was at the point where we really couldnt keep going because it was just to ugly. It was an auto, but I expected it to run better.
Old 07-01-2006, 02:50 PM
9 Sec. Club!!!
dan03mach's Avatar
How slow was it running??
Old 07-01-2006, 03:24 PM
He chose not to have his times displayed.
Old 07-01-2006, 03:34 PM
9 Sec. Club!!!
dan03mach's Avatar
Something isn't right with that car thats for sure.. I read your other post. Your 116mph trap speed and you walking away from a KB Mach just doesn't add up.
Old 07-01-2006, 04:10 PM
turns out it had a cobra blower, my bad.
