DIY - Home Ported Heads Information Page
Old 07-01-2006, 03:55 AM
kenkaru's Avatar
Default DIY - Home Ported Heads Information Page
http://www.shinken.us/DIY_heads.htm
So far I've just posted a compilation of pics that I put together for printing. I got all of the pics off this forum so thanks everyone! If you see some pics of yours, let me know and I'll put up some credits. In the future, I plan on adding notes and information that I found especially usefull.
I'm done porting mine. Just have to clean, paint em, and slap em on!
Old 07-01-2006, 07:32 AM
1dirtyZ's Avatar
great job! how did you get that kind of finish on the ports?
and what did you break into (the spot you marked with red on one of the ports)? was it a water passage or a bolt hole?
Old 07-01-2006, 07:51 AM
shouldaboughttheZ's Avatar
I would like to know also.
Old 07-01-2006, 07:52 AM
Bo White's Avatar
Good collection, I see a pic or 2 of mine in there
Old 07-01-2006, 11:35 AM
kenkaru's Avatar
Those pics aren't of the heads that I'm working on. It is a collection of pics that I put together when I was researching and preparing.
The area that you can break through on is the rocker boss (bolt hole) in the intake port. I'll put up more info on the site in a little bit.
Thanks Bo! I read a lot of your posts when I was researching.
Old 07-02-2006, 12:32 PM
GuitsBoy's Avatar
Were all those heads really hand ported? Seems like most were CNC ported and possibly hand finished.
Anyway, heres a couple of pics if theyre of any use to you. Sadly no finished pictures after I polished them up and milled. I ran into an emergency and had to get the heads on teh car ASAP and didnt get to snap and pics at the end.
http://picasaweb.google.com/GuitsBoy...dPolishedHeads
Old 07-03-2006, 03:36 AM
kenkaru's Avatar
I think most of them are hand port jobs but mainly, I was just looking for pics that show results I felt were attainable with a hand port. Thanks for the additional pics. I'll include them. The more the merrier!
Old 07-03-2006, 09:21 PM
2000TransAmWS6's Avatar
thanks for the site! i would really like to port some heads for myself... if i could ever find the time.
when you smooth down the rocker boss and expose the hole, what should you use to smooth the hole out, so that air can smoothly run over that area? epoxy?
Old 07-06-2006, 11:22 AM
kenkaru's Avatar
um I guess you could do it like a throttle body but I think most just leave it as and use thread sealer on the rocker bolts.
I'll work on the page a little more once I get caught up on school work.
Old 07-06-2006, 01:04 PM
Xtnct00WS6's Avatar
Yeah, I see some cnc track lines on some of them.
Old 07-09-2006, 08:55 PM
bump...
does anybody else know the answer to this, for certain?
Old 07-09-2006, 09:11 PM
98formulaMAH's Avatar
where do i get that SA kit you referred to in the link?
Old 07-09-2006, 09:14 PM
GuitsBoy's Avatar
bump...
I think most dont bother filling the hole at all, I know I didnt. Just make sure you use thread sealer so you dont burn oil.
Old 07-09-2006, 09:32 PM
hammertime's Avatar
Anybody have before and after numbers for the DIY porting? Dyno or ET & MPH
I've done some light port & polish work on SBC heads in the past, but not sure what the average DIY'er can achieve with LS1 heads (241) for the time it takes.
Old 07-09-2006, 09:34 PM
GuitsBoy's Avatar
I beat a car with a similar cam and stock ls6 heads by 35 RWHP. I also came within 2 HP of a 5# supercharged car.
Old 07-10-2006, 08:50 AM
thanks!
Old 07-10-2006, 09:39 AM
Xtnct00WS6's Avatar
bump...
The bolts will be sticking out of the hole, so you shouldn't fill it in. What you can do is cut the bolt ends off (intake only) to match the intake wall. I'm sure this is worth a few good cfm. What I found was when I did this that you need to make sure you put the same bolt back in the same rocker hole, b/c they are easily mismatched. You also need to make sure you torque them all to 22 ft/lbs so they're consistant. I numbered my intake bolts so I knew which one went in which bolt hole.
Old 07-10-2006, 09:41 AM
GuitsBoy's Avatar
How much was actually sticking through? Ill have to pull the intake some time and take a look myself, not that I can do anything about it now.
Old 07-10-2006, 09:52 AM
Xtnct00WS6's Avatar
Mine stuck out about a quarter inch.
Old 07-10-2006, 09:54 AM
kenkaru's Avatar
So couldn't I just cut the rocker bolt length like .250? I'm just having a hard time imagining the bolt ending up at precisely the right angle. Maybe mark the bolt heads to verify the angle?
