Crank pulley removal. Danger?
Old 07-04-2006, 10:15 AM
ShevrolayZ28's Avatar
Default Crank pulley removal. Danger?
Hey, I think I better take the car off jack-stands when I remove the crank bolt. The front is up and the back is on the ground, and I'm afraid I'll actually motivate the rear tires by turning the crank, it could knock it off the jack-stands, crushing old Shev.
Too bad, I would've liked to get under there and use leg power to turn the breaker bar lol. I think I'm gonna need a hunka-pipe.
Happy 4th!
Old 07-04-2006, 10:38 AM
cantdrv65's Avatar
Wink
Happy 4th!
You better! Dont want to get a darwin award on the 4th!
Old 07-04-2006, 10:43 AM
lol@ the Darwin award.
With my luck I'd end up trapped between the AC condenser and the motor....and suffer a slow death by starvation.
Old 07-04-2006, 10:51 AM
00transamnh's Avatar
lol put it in nutral and crank on the ebrake? natural selection is the ****
Old 07-04-2006, 11:39 AM
11Second Club
Gauge's Avatar
I didn't use a breaker bar or leg power. I used a floor jack.
Old 07-04-2006, 11:47 AM
BROKEN's Avatar
put it in 6 gear and pull the e brake byt first put it on the ground for safty
Old 07-04-2006, 02:56 PM
Grimes's Avatar
I am a 130 lb small asian guy. i got it off with a 3' cheater pipe and breaker bar from the top of the engine compartment (on the first try!).
If I can do it, you can too!
Old 07-04-2006, 03:00 PM
charlie c5's Avatar
Ok Bruce Lee, take it easy...
Old 07-04-2006, 03:25 PM
Old Shev got it off with an 18" breaker. It wasn't all that bad, but then again I am a strong ****
I did'nt lower it, I stuck it in 4th and chalked the crap out of it, both in front and behind the rear tires. Don't try this at home!
One thing though. I am not comfortable using the old crank bolt partially treaded into the crank, in the process of pulling the balancer. There's too much slop! And I can't find any threaded rod or a longer bolt at Loews or Home Depot
I'll redirect my efforts to the heads for now.
Guage, nice idea with the jack.
Later, fellas.
Old 07-04-2006, 07:57 PM
USMARINE1108's Avatar
Later, fellas.
I just did my h/c swap last week and couldn't find a longer bolt anywhere. I made due with the old bolt. It sucked and got a little hairy when the pulley came off and went back on, but it got the job done. Good luck.
Old 07-04-2006, 08:09 PM
RrCoX22's Avatar
i used a longer bolt... and that small 4" pulley puller does wonders
Old 07-04-2006, 08:28 PM
pdd
pdd's Avatar
i forgot to put the emergency brake one time(car was in gear) and as i was torquing down the crank bolt, as I cranked on the pulley bolt, the back tires moved real quick on the jackstands. i almost left a log in my draws
Old 07-05-2006, 11:42 AM
4merlt1user's Avatar
all i want to say is thanks for the laugh, im about to do mine and would not like to have to go through all of this
Old 07-05-2006, 02:07 PM
Gary Z's Avatar
The flywheel holding tool is well worth the expense, both for safety and to ensure that the crank bolt is properly tightened.
Old 07-05-2006, 02:09 PM
Grimes's Avatar
when putting it back on, use grease and heat the pulley up a little in the oven.
Old 07-05-2006, 06:07 PM
slow trap's Avatar
when i did my u/d pulley i put the 1/2" ratchet,socket on the bolt and stuck my hand on the ratchet and it turned.aparently we forgot to torque it when i did my cam install.how the bolt was still in there i don't know, i'm still amazed.
Old 07-05-2006, 06:49 PM
227Hawk's Avatar
The easiest way is put the pulley in some very hot water. The heat will expand the pulley enough to start it easy. (just remember to hold it with some rags)
Hawk
