Drag Racing Tech
Launching an M6 with DR's??
Old 07-13-2006, 04:18 PM
MavrikTA's Avatar
Default Launching an M6 with DR's??
I feel stupid even asking this, but what RPM would yall recommend for a basically stock LS1, T56 on BFG 16in DR's? Im thinkin 2500-3000k. Any advise would be appreciated.
Old 07-13-2006, 04:24 PM
Gary Z's Avatar
You will need to experiment with engine speed, tire pressure, and throttle and clutch technique.
Old 07-14-2006, 01:16 AM
SS4Luck's Avatar
i would say prolly a little higher as i come out of the whole at 2600+ with my POS kuhmos... im sure alot depends on track prep also
Old 07-14-2006, 03:20 PM
Demonicbird00's Avatar
are you on stock clutch and rear? do you have headers?
on stock clutch w/ stock manifolds go from 3500 and slip the clutch, dont dump it or youll break the rear.
on stock clutch w/ headers, slip the clutch from 4500 and go.
hope that helps
-brandon
Old 07-17-2006, 03:16 PM
MavrikTA's Avatar
Thanks guys!
Old 07-17-2006, 04:23 PM
02SOMWS6's Avatar
what rear?
Old 07-18-2006, 10:25 AM
MavrikTA's Avatar
Bone stock. 3:42's
Old 07-18-2006, 10:55 AM
o-ss-kar's Avatar
hope that helps
-brandon
Why slip it on higher RPM with headers ?
Old 07-18-2006, 03:38 PM
cause you have the better flowing exhaust to launch from your powerband. w/ teh stock manifolds youll more than likely bog.
-brandon
Old 07-18-2006, 04:25 PM
LawHorn's Avatar
I have a ram vds clutch and hooker LT's. I have 18x10 TTII's so is 3500 a good launch?
Old 07-18-2006, 09:02 PM
02SOMWS6's Avatar
If your serious about running your car at the track I would start saving for a rear or don't get too greedy at the track and launch the car on the soft side. I snapped a axel on my stock rear with 4.10 gears with just bolt-on's with less than 1,500 miles on the car. The stock rear with a m6 and a sticky tire can be broke pretty easy if your not carefull
Old 07-19-2006, 04:51 PM
yeah if your on street tires.
as long as he slips the clutch out and works the launches that way he'll be fine
-brandon
Old 07-19-2006, 07:07 PM
LawHorn's Avatar
-brandon
On some street tires. Yokohama AVS Sports. About to start some more modifications
Old 07-20-2006, 09:51 PM
yeah start from 3500 if you bog, go higher on the next run. if you spin go lower, or just dont stomp on it right away.
Old 07-25-2006, 11:48 AM
aaronbetzner's Avatar
Not to hijack but what about TSP cam 12 bolt 410's and headers and bfdr's? Stock clutch.
Old 07-25-2006, 01:33 PM
Gary Z's Avatar
Newcomers are allowed one free absurd question - you've had yours.
Old 07-25-2006, 03:01 PM
thanks richard head
Old 07-25-2006, 05:37 PM
arron.....i had your setup minus the cam and was going from 4500 on my stock internal car. on stock clutch you have to slip it. cause the stockers cant handle dumps.
-brandon
Old 07-25-2006, 06:47 PM
SLPSS99's Avatar
-brandon
But at the same time slipping the stock clutch will hurt it just as fast, you are causing a lot of heat when you are slipping the clutch. My stock clutch last about 6 track passes of 1.8 60fts with stock internals and then it was shot. Also make sure it does not dead hook from 4500 otherwise say bye bye to your 10bolt.
Old 07-25-2006, 08:42 PM
well slip it as fast as posible, my stock clutch lasted 80k and over 60 passes
hit a 11.998 w/ it and multiple 1.7s
