Little Button Under Glove Box
Just a little question,under my glove box is like a little button on the underside, ya know where your feet sit, above that,i seen it last night and thiught wtf is that??
also ..tire pressure... the tires are rated at 51psi yokohama 245 z 50s, the door panel says to go like 38 os something, i figured the 51 was too much so went w/40, should i bump the pressure up to the ntire manufactuers 51??, i am used to the regular 32 or so ..less for traction demands,thanks for the info
Not sure about the button but that pressure is WAY to high. That pressure on the tire is the max cold tire pressure. That's not what it should be run at. Your door sticker should be around 32 or 34. I usually run mine around 32. Door sticker on my car with the 17's says 30psi so I dropped them down after I put in my new tires to see how they work.
yep i think the button is the parachute!!! ha ha,, say just called gm sevice about my bubbles on the roof ...check out reply in interior and appearence
also thanks for the info on tire pressure
that's funny cause i just found a little black push button under the dash on the driver side last night. Pressed it a hundred times and nothin happened. I have no clue wtf it is
Originally Posted by Blk98ls1
The alarm is in the hatch next to the spare.
-Mike
