Sponsored by: DashLynx
Swing-Out Cup Holder Broken
Old 07-24-2006, 04:00 PM
tracetrimble's Avatar
Default Swing-Out Cup Holder Broken
I use my swing-out cupholder a lot, and now the detent mechanism (the clicker thing that holds it closed or open) on it has broken. I also found a spring laying on the floor mat that probably came from it. It's pretty much useless without the detent.
I went to the dealer, and of course they were no help. They would only sell the complete console for almost $200.
Has anyone else had this happen?
Old 07-24-2006, 04:07 PM
Fratsit's Avatar
I have'nt. You may be able to score one at a junk yard or on EBAY.
Old 07-25-2006, 03:19 PM
Thanks. Anyone else?
Old 07-25-2006, 03:37 PM
Reject's Avatar
ebay is the best bet, they have the whole console all the time there for like 80 bucks.
Old 07-25-2006, 03:39 PM
Ls1_axxxman's Avatar
I work at a dealership and one of the springs is available without the console, there r 2 though. The other does only come with the console. Here's the part # for the one that u can get alone-10281309. the only pieces of the cupholder that arent available is the one spring and the actual holder portion.
Old 07-25-2006, 03:41 PM
It's not worth $80 + the hassle of ebay and installation to me to have it working. Any ideas on another way to fix it? Maybe a big nail?
Old 07-25-2006, 03:45 PM
Check with local parts stores, most have some sort of spring assortments in the help section. i havent actually looked at the spring but judging by the pic i have, a small carb spring might work.
Old 07-25-2006, 04:09 PM
Reject's Avatar
lol not using it?
Old 07-25-2006, 04:35 PM
paspar2's Avatar
Did something actually snap and break? Or did the spring just fall out? Any way you could take the piece out and have a look? I'd go with the "pick your part" shops you could probably get it for $1.
Old 07-25-2006, 05:48 PM
dogger's Avatar
I'm willing to bet your spring just came out. it happend to me before but it's a pain to put it back in. the problem is one end the spring mount's to is can just slid off the hook.
Old 07-25-2006, 06:35 PM
2001KuztomRSEdition's Avatar
I've decided since i broke mine to mold it together and just say the heck with that lil cause its agrovating anyway...i'd rather have the cupholder in the door panel like the add on kits you could add too the 3rd gens
Old 07-25-2006, 09:00 PM
Thanks for all the replies.
I'd post the fiche from newgmpartsusa.com, but it's not the same as the fiche my dealer had. Dealer's showed the pivot bolt, a big spring around that, the little double-hooked spring (which I do still have), etc. Hmmm...
Dogger, if it happened to yours too, I bet it did just fall out. Did you have to pull the console out to get to the pivot / mount bolt from the bottom? I'll see if I can figure out where the little hooked spring goes.
Old 07-25-2006, 09:12 PM
BuBbABFP's Avatar
It happen to mine too!! it freakin sucks when u put ur drinks on there and they fly to the passangers floor mat!!! OMG it happened to me with hawaiian punch!!
Old 07-26-2006, 10:08 AM
Did you fix it, Bubba?
Old 07-26-2006, 04:54 PM
dogger's Avatar
I fixed it while it was still in the car. it did require laying the seat down and getting in it upside down(sorry pics just use your imagination) in can be done. if you remove the little cap though I think you could get it.
Old 07-26-2006, 05:32 PM
Brian2006's Avatar
gmpartsdirect.com
Quick Reply: Swing-Out Cup Holder Broken
