How To Remove The AIR Pump
I think there is a writeup somewhere. From what I can remember you just unhook the hose that connects to each manifold and follow the hose back ripping off **** as you go. Depending on your year it will be different and you may have to plug a line that goes into the back of your intake manifold. Other than that you just disconnect anything connected to the two hoses that go to your exhaust manifolds.
scott
scott
http://www.ls1camaro.net/sections.ph...ticle&artid=70
thats the best one i found when i did mine. its fairly easy to remove. the pump itself is located under the drivers side headlight.(incase you didnt know)
ok i was wondering about a write up.. i know where all the hoses are, astated above how do you get it from under the drivers head light. i know that i will have to get under hte car and access it through the little access panel held on by three bolts. shouldnt be that bad.
anymore input would be greatly apreciated!
EDIT: rading the above link, do you need block off plate??? i do not have any nor did i know you needed them
