metal inside ls6 intake manifold?
Old 07-30-2006, 10:25 PM
dvandentop's Avatar
Default metal inside ls6 intake manifold?
How could metal chunks off the piston and piston rings end up inside of the intake manifold on a ls6???
Old 07-30-2006, 10:28 PM
Ferocity02's Avatar
That's pretty much impossible short of a broken rod or a grenaded piston.
Old 07-30-2006, 10:34 PM
dvandentop's Avatar
that is what i thought probably
Old 07-31-2006, 11:41 AM
Slo_240sx's Avatar
Intake valve opens and enters the intake. I grenaded a 7.4 big block and had piston ring peices all inside it.
-Alex
Old 07-31-2006, 12:01 PM
GuitsBoy's Avatar
I would think its possible, although, it probably takes a bit of luck (or lack thereof)
Old 07-31-2006, 02:36 PM
Gingervitis Addict
slow67's Avatar
Hey Ive seen a washer move from cylinder to cylinder on a BBC. It scored 3 pistons (1 on an opposing side) before becoming lodged in one of the pistons.
Old 07-31-2006, 02:38 PM
ss1129's Avatar
Thats pretty sweet. I love destruction.
Old 07-31-2006, 09:10 PM
Ramairbird's Avatar
Default intake
Yup, I've seen it too. A v6 that had a washer dropped down the intake during a tune-up and the person working on it thought the noise was a lifter so he reved the **** out of it to try to get that "lifter" to pump up, well the washer went in and out of 5 cylinders and finally did enough damge to where it stopped running.
Quick Reply: metal inside ls6 intake manifold?
