HV oil pump dillema
HV oil pump dillema
My car is currently undergoing a H/C/I swap.
It is a 2001 SS. My oil pressure before the swap was always BOMB....much higher than my buddies F-bodies......even one that has a ported LS6.
At startup it is dam near 60psi (idle), and drops to about 50 psi at idle once it warms. It is well over 60 at WOT.
Well, to be safe since my motor was open, I ordered a GMPP High Volume oil pump: http://www.sdpc2000.com/catalog/4460...S-Oil-Pump.htm
Well, I am just scared that I will actually see a loss in oil pressure after the swap since I sem to have a factory freak pump in my car right now.
BTW--I run M1 5-30
Thoughts?
BTW--I run M1 5-30
Thoughts?
Originally Posted by orangeapeel
Don't worry....It has been happening since the 5th post.
I know I would be fine with a small drop in pressure but it is just kinda depressing
One of those "If it ain't broke don't fix it" dilemmas.
The current pump (before swap) has 50k on it though, so I figured I'd replace it.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by ninetres
Who said it was a ported LS6
It is my stock orig pump from 2001 w/ 50k on it.
Switch to an LS6 pump straight up. Don't get a ported one if you are worried about what it reads. Plus high volume isn't the answer in most cases.
Haha, so that explains that. Switch to an LS6 pump straight up. Don't get a ported one if you are worried about what it reads. Plus high volume isn't the answer in most cases.
HV for $66 > LS6 for $100+ IMO
I think the one in my car to start with might be an LS6, I remember reading they came stock on 2001s
Well go to bed, and maybe Fidel Castro will be dead in the morning.
Did anyone ever bother to check the oil pressure gauge against an aftermarket one tapped into the block to see if its accurate? The factory pump has a pressure relief spring set for 55psi which it should reach at 5,000 rpm at temperature. Alot of the ported pumps have a stronger spring/shim to raise the pressure thats how they get higher volume. Unless of course yall beleive that the accuracy of the GM gauges are infallible.
