HV oil pump dillema
It is a 2001 SS. My oil pressure before the swap was always BOMB....much higher than my buddies F-bodies......even one that has a ported LS6.
At startup it is dam near 60psi (idle), and drops to about 50 psi at idle once it warms. It is well over 60 at WOT.
Well, to be safe since my motor was open, I ordered a GMPP High Volume oil pump: http://www.sdpc2000.com/catalog/4460...S-Oil-Pump.htm
Well, I am just scared that I will actually see a loss in oil pressure after the swap since I sem to have a factory freak pump in my car right now.
BTW--I run M1 5-30
Thoughts?
That thread inspired this one actually. I didn't want to highjack his ****
I know I would be fine with a small drop in pressure but it is just kinda depressing
One of those "If it ain't broke don't fix it" dilemmas.
The current pump (before swap) has 50k on it though, so I figured I'd replace it.
It is my stock orig pump from 2001 w/ 50k on it.
Switch to an LS6 pump straight up. Don't get a ported one if you are worried about what it reads. Plus high volume isn't the answer in most cases.
HV for $66 > LS6 for $100+ IMO
I think the one in my car to start with might be an LS6, I remember reading they came stock on 2001s
okkk?....i dont see how that will keep all the illegal cubans from still trying to take over my state?
...but hes a mean old man anyway...and the US could use another vacation spot
