turbo on/off
Old 08-07-2006, 04:52 PM
number1gun's Avatar
Default turbo on/off
is there any kind of turbo that can be turnd on and off
or would you have to fab up a way to make the air bypass is
number1gun is offline
Old 08-07-2006, 04:54 PM
ABeasst's Avatar
are you actually serious? Have you been watching Mad Max the movie.
ABeasst is offline
Old 08-07-2006, 05:01 PM
forgedbluess's Avatar
Are you drunk? thats prolly the dumbest thing ive heard sence well ummm, that.
forgedbluess is offline
Old 08-07-2006, 05:03 PM
Tiago's Avatar
Tiago is offline
FormulaFire's Avatar
Is this the comedy section?
FormulaFire is offline
Old 08-07-2006, 05:06 PM
Camaro_Zach's Avatar
bs aside though, youd have to have one mother ******* trick setup. think of like a cutout that would block air to the turbo (close the cutout) and would then allow air out the other pipe, aka to the back of the car, so each header would have to have a Y pipe if you will. not sure about air intake at that point. youd probably need a Y on the charge pipe going to the TB as well. one going to a filter, one goin to the intercooler. (this is all in theory) basically like a mamoth manual "wastegate" before anything.
in conclusion, no. unless you have a KIA motor in your 3rd gen engine bay.
and who the f' would wanna turn a turbo off? isnt that the point of spending all the money? haha
Camaro_Zach is offline
smoke20's Avatar
the only way it possibly would work is if you installed a flux capacitor to generate enough voltage to overcome the flow of exhaust,
smoke20 is offline
Old 08-07-2006, 05:10 PM
slow's Avatar
Turbo's are load based, part throttle, your bypass can stay open, preventing boost. when you go deeper into the throttle, you will get boost.
Ryan
slow is offline
Board Certified Idiot
Z2K_MrJ's Avatar
I think your Idea.. Is Ahead Of Todays Moddern TECH. But I am sure its possible and will Be done.
Z2K_MrJ is offline
Old 08-07-2006, 05:18 PM
NoMoreLS1's Avatar
Thumbs up
Actually the Mad Max car was supercharged. Here is the actual Max Mad car. Right here in Naperville, Illinois. It belongs to the owner of Best in Show (classic car restorations). He does drive it as you can tell by the bugs on the front end.
Attached Thumbnails turbo on/off-mad-max-2.jpg   turbo on/off-mad-max-3.jpg   turbo on/off-max-max.jpg   turbo on/off-mad-max-4.jpg
NoMoreLS1 is offline
Old 08-07-2006, 05:22 PM
number1gun's Avatar
ok picture this you have your header leading into your turbo but ahead of you turbo rou put a cut out that leads back into the exhaust after the turbo i.e. open = boost closed = the bility to open it and wake up a sleeper car
and i want to do a sleeper build thats why i made the topic
Old 08-07-2006, 05:29 PM
NoMoreLS1's Avatar
Smile
That would be interesting to try to tune.
so then exactly what i said.
Wnts2Go10O's Avatar
is been done on a vw in a way on the intake side i believe. they have an s/c/turbo car
you eould havr to have 2 y-pipes on the exhaust side with cutouts and you could leave the intake as it sits.
Wnts2Go10O is offline
Old 08-07-2006, 05:34 PM
number1gun's Avatar
yes i just put it so the less minded could wrap themselfs around the idea
Old 08-07-2006, 06:21 PM
ABeasst's Avatar
I know but it was the only thing to compare it to.
ABeasst is offline
Old 08-07-2006, 06:41 PM
Boostaholic's Avatar
Why in gods name would you want the turbo OFF?
Boostaholic is offline
Old 08-07-2006, 08:20 PM
number1gun's Avatar
in one word sleeper
in more than one a sleeper i mean come on no one has a sleeper with a turbo
Old 08-07-2006, 08:27 PM
mahhddgtp's Avatar
Save money... Forge a 402/403 LS2 or a 408 LS1... Go with a badass Nitrous setup. 200-250shot.
mahhddgtp is offline
Old 08-07-2006, 08:41 PM
Lafngas98Z's Avatar
Do you have any idea how crappy the car would run with the turbos "off". The tune and injectors would be WAY off. I cant believe I posted in this thread
Lafngas98Z is offline
Quick Reply: turbo on/off
