truck throttlebody on a ls1??????
Moderator
I guess it depends on the truck. The core I ported
was off a truck and the casting numbers were
identical; differences were the shaft cam (smaller)
and the coolant and PCV bungs. I swapped over
the PCV snout but just cut off the whole coolant
boss, fittings and all. If it's a cable throttle truck
I believe you will find the same.
There are several TBs that will work. I have a book that lists all of the ones that will work from Vortec power trucks/suv's, unfortunately I'm not home right now. PM me if you would like me to look up the information, i'd be glad to.
