Fueling & Injection - Speed Inc fuel rail problem
2001 Pewter WS6
08-16-2006, 10:54 AM
I bought a set of used Speed Inc fuel rails and read on their site that the fitting was supposed to be 3/8" NPT. So I ordered the fitting from Summit and it was too small. I could slide the fitting in and the threads wouldn't touch. So I figured it had to be 1/2" NPT and when I tried it, it was too big. I seems like it needs to be 7/16" NPT but there is no such size. Does anyone know what size it actually is??? I guess the older fitting's were a different size at some point in time...
davered00ss
08-16-2006, 11:05 AM
I just ordered FAST fuel Rails, and the AN fittings do not screw right into the rails. There is a plastic Male/Male screw fitting that goes into the rails, then to the AN fittings. That is probably what you are missing.
davered00ss
08-16-2006, 12:10 PM
Black fittings in pic.
http://i3.photobucket.com/albums/y63/dgrundwalski/Picture405.jpg
Try to PM Nate from Nasty, I'm sure he can help you.
2002_Z28_Six_Speed
08-16-2006, 01:31 PM
That is a good looking product. If you have the proper fitting is the rest of the install pretty simple?
Do factory injectors fit that fuel rail?
davered00ss
08-16-2006, 03:01 PM
They better. :jest: If not I'm screwed. :jest:
davered00ss
I just ordered the fittings & fuel line from Nasty. :)
Country Boy
08-16-2006, 04:36 PM
Make sure youre not using AN fittings instead of NPT. My Speed Inc rails are 3/8 NPT.
SVC707
08-16-2006, 08:42 PM
i just checked mine and they are infact 3/8 npt part number is "fcm2007" 3/8npt to -8an
"fcm2005" 3/8npt to -6an
hope that helps
SVC707
08-16-2006, 08:46 PM
http://img.photobucket.com/albums/v482/svc707/IMG_0310.jpg
fittings galore let me know what end you need and ill look it up for you
2001 Pewter WS6
08-17-2006, 08:35 AM
A friend of mine had an -8an fitting and it screwed right in. There was no way the 3/8" NPT was right, I tried it and the threads didn't even touch. Way too small....
1QUIKWS6
08-23-2006, 06:42 AM
Are you sure the rails are NPT? Every rail I have seen has straight threads in each end - hence the reason you use the fittings with the O-rings as pictured in the post showing the FAST rails...
-Jay-
RedWS6 00
08-23-2006, 07:45 AM
Yep they do.
2001 Pewter WS6
08-25-2006, 01:26 PM
I used -8an with an o-ring and it worked like a champ....
C5Fire
08-25-2006, 02:38 PM
Aeromotive just came out with a direct bolt on rail kit for the 98-02 LS1 f-body. Comes with rails, fitting and braided lines. It even comes with an adapter to plug into the stock feed line and changes it to two -8AN feeds. A buddy of mine just got the prototype system installed. Looks great!
Black Plague
09-17-2006, 12:30 AM
Cant wait to get the kit! Is there any Idea on when they will list the kit for sale?
Jimmyz
09-20-2006, 08:17 PM
I just found it on Summits site:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEI%2D14106&N=700+115&autoview=sku
Black Plague
09-20-2006, 08:24 PM
Those are just the rails. See the post fuel rails whats needed? I belive part# is 14139.
C5Fire
09-21-2006, 08:57 AM
Just call summit and tell them you need a special order. Aeromotive just released part # 14139 which is the 98-02 F-body rail kit. It came with everything to replace the factory rails. No need to guess what fittings to get and how much line, staight forward and simple.
