Sponsored by: DashLynx
new project to clean up engine bay.
Old 08-20-2006, 03:15 PM
ls2 bait's Avatar
Default new project to clean up engine bay.
made these little panels to try and clean up some of the rats nest worth of wiring under the hood. still havent decided what to do about the battery and fuse boxes and im working on trying to get some frc's cut to put on to hide some of the other stuff. they will be black to match the engine bay.
Old 08-20-2006, 03:21 PM
1SicV8's Avatar
not bad, i like the headlight ones...
Old 08-20-2006, 03:26 PM
SS4Matt's Avatar
looks interesting....can't wait to see the finished product!
Old 08-20-2006, 03:42 PM
~JOSHUA's Avatar
How are you going to finish the panels? Show some attention to the borders closest to the headlights.
Cool to see the progress! I love the pcm cover. ~Joshua
Last edited by FIREHAWK#608; 08-20-2006 at 04:24 PM. Reason: spelling.. spleleing :P
Old 08-20-2006, 03:53 PM
Duffster's Avatar
nearly the same idea I started last night. . .I intend to fiberglass panels instead of metal. Good start!
Old 08-20-2006, 04:18 PM
parbreak's Avatar
Here's what I made. Not completely finished yet, but close enough you get the idea:
Bryan
parbreak
Old 08-20-2006, 04:52 PM
ls2 bait's Avatar
i really like that. i tired a couple things similar but the hood kept on hitting it so i ended up having to make something that went along with the lines of the pre existing peices.
Old 08-20-2006, 04:53 PM
ls2 bait's Avatar
not sure yet. i though of using them as a mold per say and doing fiber glass. im going to try and get them to match the engine bay paint as best as i can. what do you mean about the headlights?
Old 08-20-2006, 05:05 PM
ls1king000's Avatar
I'm liking what I see!! Keep up the great work guys!!
Old 08-20-2006, 05:13 PM
parbreak's Avatar
I was worried about that too the first time I closed my hood, all that work and the hood smashes the **** out of my carbon fiber!! Luckily it doesn't hit at all. The large hole is so the "SS" hood ductwork can clear along with the hood latch.
Bryan
parbreak
Old 08-21-2006, 09:15 AM
ls2 bait's Avatar
ive thought of trying to use some kind of foam and taping everything off as well as the hood then closing the hood so it would form the shape and then sanding it down to make a smooth sold peice. any idea what type of foam or the like to use? i thought the great stuff foam but dont want my hood to be stuck closed
Old 08-21-2006, 09:41 AM
Snootch's Avatar
I believe you could use great stuff, but before you spray it in there, spread a thin layer of vaseline on both surfaces to act as a release agent. When it's hardened, you should be able to pop the shaped foam piece out and clean up the vaseline. A hacksaw blade works really well for trimming hard foam. Once you have a shaped foam piece that is the right shape, create a fiberglass mold from it. Then you could make a fiberglass piece from the mold. Here's a tutorial from Fbodyaudio.com for making molds: http://fbodyaudio.com/articleviewer....cle=molds.tech
Old 08-21-2006, 11:41 AM
Proximo's Avatar
lookin good guys
Old 08-21-2006, 04:51 PM
LvDemKings's Avatar
The PCM cover looks great. That'll probably be my next project. I'm guessing that's just sheet metal you used? Looks very similar to the battery cover I made (trashed now because I want to go polished instead of painted). Just to give you an idea for making one for yours, I used the headlight bracket bolt to secure it so I could leave it on while driving. BTW, I didn't have top post terminals on my battery like the Optimas do.
Old 08-22-2006, 07:53 AM
twisted01ss's Avatar
Looks good. I haven't even had a chance to get back on working on mine. Hurry up and get them painted and post up some more pics.
Old 08-22-2006, 09:44 AM
Luster's Avatar
And just when I thought I was done customizing my engine bay!!!
Nice ideas guys!
My main concern is not hiding the wiring harnesses, but that gray plastic and the gaping hole between the nose and the radiator!!!
This picture has me thinking... hhhmmmmm...
(STOP DOING THAT, BRYAN!)...
Old 08-22-2006, 10:00 AM
parbreak's Avatar
I can't help myself. I've entered a 12 step program for "mod-a-holics" but dropped out after 3 steps
Old 08-22-2006, 10:08 AM
Luster's Avatar
LOL... I'm afraid I'd never get past Step 1 !!!
Old 08-22-2006, 11:18 AM
schmidt69's Avatar
looking great man, wish i had the time to do something like that
Old 08-23-2006, 10:13 AM
ls2 bait's Avatar
anyone else have an idea of what i could put in this area and close the hood so that it would give me a mold of the open spaces and maybe make a nicer peice out of fiberglass or the like? the great stuff doesnt seem to want to dry on top of the vaseline and i painted them to give me an idea of the final product but not sure if i like it now.
Quick Reply: new project to clean up engine bay.
