help with my 95 Formula tranny....
Old 08-21-2006, 08:30 PM
Alz
Alz's Avatar
Default help with my 95 Formula tranny....
i have a 95 formula..and the tranny is shot.. i was looking for a used one from some local salvage yards and was told my tranny is 1995 specific???? so im wondering..is this true? if so..does the used one need to be from another 95? and...does anyone know where i could hunt down a used one...
Old 08-21-2006, 09:38 PM
onebadblackz's Avatar
I have a 95 camaro it had a 4L60E in it but I put a B&M 700R4/4L60
Old 09-01-2006, 02:29 AM
Alz
Alz's Avatar
the 700r4 goes right in?
Old 09-01-2006, 07:00 AM
FLT
FLT's Avatar
What you heard is true about the 95 units is true. If there is something we can do give us a call anytime. Vince.
Old 09-04-2006, 11:37 PM
Alz
Alz's Avatar
well im wanting to know if any other trannys will work? whats different in the 95s?
Old 09-05-2006, 08:01 AM
FLT
FLT's Avatar
Pump, valve body, seperator plate, and electronics.
Old 09-05-2006, 09:55 AM
dhdenney's Avatar
The 700r4 does go right in. Some things you have to consider though is you are foregoing your computer shift. So now instead of the PCM deciding on shift points, weights and springs in the governor will now do that and might not be where you want them. Your PCM might need to be reflashed to avoid tranny DTCs. Your speed sensor will plug right in if you reuse your tailshaft. You will also need to pickup a 1993 throttle bracket for the kickdown/TV cable. I went 700r4 and now I kinda regret it. If you want to go 700r4, PM me and I'll swap you harnesses. I'm really considering going 4l60e.
Old 09-05-2006, 09:56 AM
dhdenney's Avatar
Forgot to add you will need to add an aftermarket lockup control like the B&M.
Old 09-05-2006, 07:12 PM
Alz
Alz's Avatar
ok well im not looking to do all that really..so im pretty much stuck with getting this one rebuilt or hunting down a used 95 tranny...?
