oil pickup tube question
Old 09-04-2006, 12:08 AM
Cop Car's Avatar
Default oil pickup tube question
you guys think this dent in my oil pickup tube is an issue? this is the end that goes into the oil pump. it is only at the end and is very small, also it is not at all bent in the o ring area.
Old 09-04-2006, 03:55 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I think that you should be fine with it. How did it get bent though?
Old 09-04-2006, 11:51 AM
Ferocity02's Avatar
As mentioned, as long as the o-ring seat isn't out of round you shouldn't have any issues.
Old 09-04-2006, 01:36 PM
Cop Car's Avatar
honestly i have no clue. and i cant like bend it back with pliars, somehow it got tremendous force put on it. it might have been while the motor was appart or in transit.
Old 09-04-2006, 02:20 PM
kossuth's Avatar
If it bothers you enough you might be able to get a conduit expander or a copper pipe expander from lowes or home depot.
Old 09-04-2006, 03:59 PM
SDMForever's Avatar
they are not expensive replace it! Is it worth taking a chance of depriving your engine of oil and then it seizing up. I say replace it. whats 30 bucks
Old 09-04-2006, 04:33 PM
SSDoubleK's Avatar
If your down that far, take the extra time out and change it, better safe than sorry, I always get burned when trying to cut corners.
Old 09-04-2006, 04:36 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Honeslty with the oil pressure thing and LS1's. I would probably spring for a new one and just turn that one into a drinking straw. Better safe than sorry.
Cop Car's Avatar
well there are like 10 things that you can look at in a motor and be like "why dont i do that while im in here" result is you go way over budget.
i think that im going to try to get an expander
Old 09-04-2006, 04:37 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I would change it if you cant get it bent back somewhat.
