3.5in Collector to 3in Xpipe system?
Old 09-05-2006, 06:42 PM
hashtagBMW
Speed Density's Avatar
Default 3.5in Collector to 3in Xpipe system?
Car is a 396 Stroker, big heads, big cam, big shot. Thats being subtle.
Anyway right now the car has 1 3/4-1 7/8 Stepped LTs with 3.5in collectors and im trying to go easy and do the summit x pipe kit.
They only offer 3in at most thought. Is that smart to use? Collecotr wont be able to scavange very well with a .5 drop right after it.
If not im going to have to fab a 3.5/4in kit up.
Tony.
Old 09-06-2006, 02:11 AM
hashtagBMW
b U M P
Old 09-06-2006, 02:30 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
3.5" is huge even for a 396. I think that you should be fine with the 3" honestly.
Old 09-06-2006, 08:42 AM
V6 Bird's Avatar
Negative..
I noticed substantial gains on a stock long block 346 with a decent size nitrous push...im talking up to 40 hp gains in some spots of the curve..
Ive always used the rule of thumb to match the collector size to the size of junction...
3.5" collector gets a 3.5" crossover/X-pipe setup....I ran 3.5" duals dumped at the axle on my car it was well matched.
If theres one thing ive learned over the past 5+ years messing with exhaust setups and LS1s in particular...You cant over exhaust an LS1.
Old 09-06-2006, 06:36 PM
dug
dug's Avatar
how did it sound?
Old 09-06-2006, 07:50 PM
hashtagBMW
Lt1 fellas.
Old 09-07-2006, 02:26 PM
V6 Bird's Avatar
Originally Posted by Speed Density
Lt1 fellas.
have you ever heard of anyone over exhausting a SBC either? prolly not
Old 09-07-2006, 02:31 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I had the same headers, and ran 3.5 pipe into a 3.0 Kooks X pipe. We got all the pipe from Kooks. I made 754rwhp with my old blower setup @ 6600 rpms.
Old 09-07-2006, 06:03 PM
hashtagBMW
Well I guess I can mandrel bend some 3.5 and run a 3in junction and then 3in mufflers and dumps.
Old 09-09-2006, 05:10 PM
hashtagBMW
b U M P
Old 09-09-2006, 08:20 PM
00454sscamaro's Avatar
im interested as well, but from the looks of it i am going to hafto go look at a local speed shop to see if i can get something fabbed up, or just see if they got tubing and benders big enough. i know they do 3" wich is bigger then any actual exhaust shops around here... they look at you like your from another planet if you say anything above 2" at the local meiniki or w/e it is.
Quick Reply: 3.5in Collector to 3in Xpipe system?
