Gaining HP naturally aspirated?
All of my mods are in my sig. other than long tubes and a LS6 intake what else can I do to gain some good HP staying N/A
ported fast 90mm. NW 90mm
underdrive pulleys
electric water pump
Just curious do you have a dyno grapgh for the mods you have now?
underdrive pulleys
electric water pump
What are Stage 2 heads?
Better intake, better exhaust, better heads, wilder cam (yes I know ), larger displacement, higher SCR/DCR, a tune.
Plus there's always things like weight reduction and chassis mods which help deploy the power better and make more use of it. Body mounted torque arm, LCA, SFC, etc.
A 150 shot of nitrous would also see a significant gain in HP. Ok it's not n/a but unless you are racing in a class which prohibits such things who really cares. HP is HP, and the person with the most usually stands the better chance of being faster.
with a cam that size and decent heads a 90/90 with a set of lts and a tune will net you some decent gains and the ud pulley should give you alittle also.as 300bhp has asked you may have stage 2 heads but some stage 2 heads are totally different than someone's else stage 2 heads and if your dcr is low with those heads a head with a smaller combustion chamber will benefit you.
