ls-1, can it make 625 flywheel hp n/a
Old 09-26-2006, 09:20 AM
68protouring454's Avatar
Default ls-1, can it make 625 flywheel hp n/a
hey guys i got an asa ls1 it makes 430 hp as is, however i want to make around 600-625 hp n/a at 11-1 compression, i think i will need to stroke it to 400 or so to make the power i want, but figured you guys are the ones to ask, let me know what the best way to go is.
thanks
jake
Old 09-26-2006, 09:25 AM
PREDATOR-Z's Avatar
Yeah it is achievable, but not cheap
Old 09-26-2006, 09:26 AM
Default thanks
but i asked how i get there not how cheap it is.
i was looking for guys who have done it and what parts should be used
Old 09-26-2006, 09:31 AM
300bhp/ton's Avatar
Yes I suspect it is physically possible. But in reality I highly doubt it would be anywhere near streetable, usable or reliable.
Specific out, as in bhp per litre is a good guesstimate.
A properly decent h/c bolt on Ls1 can make 480rwhp for street use on a Dynojet. This is somewhere in the region of 449rwhp SAE on a Mustang Dyno, and means the engine if rated to FULL SAE Net standards would likely be around 500-530bhp SAE Net.
This means 530 / 5.7 litres = 92.9bhp/litre
For an OHV push rod V8 this is a superb figure. Most older OHV V8's won't get anywhere near this and still be streetable.
But to achieve 625bhp (625 / 5.7 = 109.6bhp/litre) you would need to run a much higher specific output.
This number is attainable, but I would imagine it would be circuit use only.
Larger displacement would be much easier. Using the same state of tune that is known to work 92.9bhp/litre we can work out what size engine would be required.
625bhp / 92.9 = 6.73 litres
So a 408ci running the same state of tune (specific output) should be able to make that number and be streetable and reliable.
Old 09-26-2006, 09:41 AM
Default thanks
sounds good, so it needs to be stroked, now, what crank kits do you guys like?
can an ls-1 be stroked to 408 or about without re sleeving?
so stroke it, put a ported or afr head onit with a .600 or so lift cam with dur in the high 230's at 50, and its there?
thanks for the help, this will be the first lsx motor i have had, i have always had old school small blocksand big blocks
thanks, let me know some combos that people have done and have dynoed, i tried searching but did not find much, i may have been looking in the wrong spot
jake
Old 09-26-2006, 10:15 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Put a Procharger D1SC on that thing and enjoy the horses. You will put that at the wheels easily.
Old 09-26-2006, 10:17 AM
Studytime's Avatar
If reliability is a concern, then I think this is a far better candidate for a forced induction setup. It will probably be cheaper too.
Ben T.
Old 09-26-2006, 10:29 AM
Default motor
thanks guys
its not a daily driver, its a streetfighter 68 camaro its going in, and will be used hard on the street and at the road race course etc, car has a 3 link rear, custom front sbframe etc, so it can be alittle tempermental, i was going to put a 409 chevy bb in it , that had afr heads, 11-1, solid roller .710 lift, 262/266 dur @.50 on a 110, but at 360 lbs you can't beat a lsx.
say i kept the 347, what could it do for hp/tq qith ported heads, and a nice cam?
Old 09-26-2006, 10:33 AM
sprayjunkie's Avatar
A friend has a Z06 with MTIs 427 package, it makes over 550+ at the wheels, perfectly streetable, drives over 135 miles on weekends from his house to mine. (gotta be over 625 flywheel Id think.) Cant argue with 130mph trap speeds on motor!
Old 09-26-2006, 11:19 AM
SSilverSSurfer's Avatar
you sure cant, theres a dude in houston who drove his there and back(Powell), ran a 10.55 @ 130, check out the vid in the texas section
Old 09-26-2006, 11:49 AM
Default ok
so i know i need to stroke it to get 600 hp.
what are some combos of stock stroke/bore ls-1s??
can a ls1 make 525 flywheel hp and 450 rwhp? thru a m6? if sd will a set of ported ls6 heads and cam do it?
Old 09-26-2006, 03:44 PM
300bhp/ton's Avatar
There are quite a few different combo's, do a SEARCH in this forum. Other option is to buy a 408ci long or short block. TSP sells them, they are cast iron using the LQ9 as a bases. If you want aluminium then they also sell a LS2 based 402ci.
But as mentioned, boost maywell be a sensible idea. Forged internals a few bolt ons and FI would be easy to make 650rwhp, so well over 700bhp. And probably for less money also.
Old 09-26-2006, 04:00 PM
silver01z06's Avatar
look into a long from a sponsor like LME, heads from someone like afr, tea, etp and you can make 500 to 550 at the wheels. that should put you pretty close to your goal of 625 flywheel. you will need all the supporting stuff like fast intake, headers etc etc.
expected cost 7-8,000 just guessing.
Old 09-26-2006, 04:04 PM
2002/Black/SS's Avatar
if ur looking to stick to an ls1 block u have to get the darton sleeve kit or equivelent. but i dont reeally know y ud want to sleeve an ls1 when u can get an ls2
Old 09-26-2006, 04:05 PM
770Guy's Avatar
I got 850 out of my C5R block and heads setup. Vengeance Racing. They are actually trying to get another 100fwhp out of it as we speak.
Vengeance Racing
Office- 678-513-7105
Quick Reply: ls-1, can it make 625 flywheel hp n/a
