arp studs tourque
arp studs tourque
is there a sequence, the lil peice of paper they give you looks alil universal and only says 65ft lbs .. i know the little ones dont get that much? and just 65fts on the first pass or 3etc passes greater each time ?
Main stud kit #234-5608,inner 60 ft-lbs with moly lube,outer50 ft-lbs with moly lube,side 19ft-lbs with moly lube as per sheet with kit,hope this helps.
Heres the procedure I used for my head studs...
1) Put moly lube on both ends of the studs
2) Thread the studs in hand-tight plus a small amount, like 10 degrees or so, snug
3) Put on the head gaskets the correct way, dont block the water passages
4) Put on head
5) Put on all of the washers with moly lube on both sides
6) Put on the nuts with moly lube on the bottom face
7) Tighten all the nuts to hand tight
8) Follow torque sequence and torque 1-10 to 30 ft-lbs. Do this three times as they will all loosen up as the head gasket compresses
9) Then torque to 50 ft-lbs, do this twice
10) Then torque to 70 ft-lbs
11) Torque 11-15 to 25 ft-lbs
12) Wait at least an hour(the longer the better) and go back and torque them all down again
Of course make sure the holes are clean and coolant free. Use the torque sequence below.
ARP changes their torque specs from time to time. Figure out what part number you have and go to the ARP website. They have a spec page for each. I have bolts, not studs, but a couple years ago the final specs for the big bolts were 70 ft/lbs and for the small bolts were 22 ft/lbs. Now it's 75 and 25.
