arp studs tourque
Old Sep 28, 2006 | 06:22 PM
00454sscamaro's Avatar
Default arp studs tourque
is there a sequence, the lil peice of paper they give you looks alil universal and only says 65ft lbs .. i know the little ones dont get that much? and just 65fts on the first pass or 3etc passes greater each time ?
Old Sep 28, 2006 | 06:27 PM
vettenuts's Avatar
I called them three times, all three times they told me 70 lb-ft with the ARP Moly lube. I would do 3 steps, 30-50-70.
Old Sep 28, 2006 | 06:33 PM
weird, says 75 for iron and 65 for aluminum on the paper, how much for the 10 small studs? thanks.
Old Sep 28, 2006 | 10:31 PM
streetlegalls1's Avatar
Main stud kit #234-5608,inner 60 ft-lbs with moly lube,outer50 ft-lbs with moly lube,side 19ft-lbs with moly lube as per sheet with kit,hope this helps.
Old Sep 29, 2006 | 02:24 PM
yep thanks
Old Sep 29, 2006 | 08:26 PM
Ferocity02's Avatar
NO!!! Thats for ARP main studs, not head studs.
Heres the procedure I used for my head studs...
1) Put moly lube on both ends of the studs
2) Thread the studs in hand-tight plus a small amount, like 10 degrees or so, snug
3) Put on the head gaskets the correct way, dont block the water passages
4) Put on head
5) Put on all of the washers with moly lube on both sides
6) Put on the nuts with moly lube on the bottom face
7) Tighten all the nuts to hand tight
8) Follow torque sequence and torque 1-10 to 30 ft-lbs. Do this three times as they will all loosen up as the head gasket compresses
9) Then torque to 50 ft-lbs, do this twice
10) Then torque to 70 ft-lbs
11) Torque 11-15 to 25 ft-lbs
12) Wait at least an hour(the longer the better) and go back and torque them all down again
Of course make sure the holes are clean and coolant free. Use the torque sequence below.
Old Sep 30, 2006 | 01:24 PM
thanks man, i had the heads hand tight for day or so now, just havent tourqued them yet.
Old Oct 1, 2006 | 06:20 AM
MiaSSmaro98's Avatar
thats a nice response let me save that
Old Oct 1, 2006 | 08:11 AM
silverZ98's Avatar
i went 30-50-75 and the small top 5 i went 22ft. my bolts was used so i didnt go over them and are still tight and running good
Old Mar 19, 2013 | 12:36 PM
MillsMotorvation's Avatar
Thanks for this info!!
Old Mar 19, 2013 | 01:25 PM
Ferocity02's Avatar
This thread is like 6.5 years old. I think ARP now says 80 ft-lbs for the studs.
Old Mar 19, 2013 | 02:01 PM
batboy's Avatar
ARP changes their torque specs from time to time. Figure out what part number you have and go to the ARP website. They have a spec page for each. I have bolts, not studs, but a couple years ago the final specs for the big bolts were 70 ft/lbs and for the small bolts were 22 ft/lbs. Now it's 75 and 25.
Old Mar 19, 2013 | 03:07 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
That's where mine are. 75/25 in 1/3 increments.
