what kinda gauges?
Old 09-28-2006, 07:44 PM
transamfreak01's Avatar
Default what kinda gauges?
i am doing a 3 pillar pod... i was going to go with n2o pressure, a/f wide band, and not sure about the third... what would you go with based on my sig and what kinda gauges would you suggest?
Old 09-28-2006, 08:11 PM
99camarosupersport's Avatar
a more accurate that stock tach?
Old 09-28-2006, 08:16 PM
Tainted's Avatar
a REAL temp guage!
Old 09-28-2006, 08:19 PM
ok but what 3 would you go with and what kind?
Old 09-28-2006, 09:06 PM
Out1aw's Avatar
If you're going with a nitrous setup then get an A/F gauge so you can spray at the right times. Also, why did you go with a MS4 if you have a nitrous setup? You're actually hurting your potential power with that cam.
Old 09-30-2006, 03:44 PM
really i was told that n2o and that cam make a great combo..
Old 09-30-2006, 03:50 PM
BriancWS6's Avatar
When I get mine I want a wideband, N2O pressure, and coolant temp.
Old 10-01-2006, 03:22 PM
is coolant temp really necessary for my type of car? im not buildin a single digit car here...
Old 10-01-2006, 04:07 PM
SLVR_99-Z's Avatar
if you can afford it i would get the interceptor gauge. covers like 15 different readings and i'm pretty sure that they can read and clear codes. do search on them. they're cool but a little pricey.
Old 10-01-2006, 08:11 PM
yeah i looked it up and it seems pretty cool but how accurate can that be for around 300 or 400$????? amd plus i would have to flip back and forth to check to see how im doing??? i think that would be a pain in the ***. i think id rather jus have my gauges and glance at them every so often... jus seems like something else to distract me
Old 10-04-2006, 01:24 PM
to-fst-4u's Avatar
trans temp.
Old 10-04-2006, 03:06 PM
TRYMY Z's Avatar
I have a 3 pillar pod in my '02 Z28 that i'm selling. They have DynoTune red led gauges; it comes with a n20 psi, fuel psi, and a/f ratio gauge. Let me know if you'd be interested.
Color Display: Red LED Display
Front Face Color: Black Face
Package Style: Black Bezel
http://www.dynotunenitrous.com/store...p?idproduct=21
http://www.dynotunenitrous.com/store...p?idproduct=19
http://www.dynotunenitrous.com/store...p?idproduct=15
Also, attached to the side of the pillar, I have an AutoMeter (ATM-5340) shift light with red lens conversion (ATM-3252) to match the gauges and comes with Autometer RPM Pill Kit 6,000 - 6,800 rpm (ATM-5356).
http://store.summitracing.com/partde...5&autoview=sku
-Mo
(916)616-9999
Old 10-04-2006, 03:34 PM
pewter 01 SS's Avatar
-Mo
(916)616-9999
how much do you want for them? pm please.
Old 10-04-2006, 04:12 PM
Y2K Z28's Avatar
well my three gauges of choice would be nitrous pressure if the car had it. A real temp gauge for those hot days. And an amp gauge to keep a better eye on the electrical system.
