not sure what this sts part is???
Old 09-30-2006, 02:52 AM
rudyzturbota's Avatar
Default not sure what this sts part is???
is this a oil catch can or something, it looks like a little pump, an has oil lines going to plus has a wire as well, id just would like to know what it is exactly, also when i was running on the dyno i notice alittle oil spraying from there, is this commend? thanks of any info.
Old 09-30-2006, 04:38 AM
navymitch12's Avatar
you prob have it hooked up wrong....its a pcv switch...
it basically vents your crank case when you are boosting....
and than when your under vac it switches back to the throttle body
read the instrustions it shows you where to put it and how to hook it up.
Old 09-30-2006, 10:25 AM
TchargedLS1TA's Avatar
Instructions are your friend
Old 09-30-2006, 12:53 PM
well i dont have any, the guy i bought it from hooked everything up wrong, so im having to go back though it figureing all this out, can some one just show me a pic on how they got theres hook up, thanks
Old 09-30-2006, 01:24 PM
reocamaro's Avatar
Mine seems to be pretty covered in oil. I've had mine on for over a year. Is it common to have so much oil on it?
Old 09-30-2006, 01:38 PM
dont think so, ive seen some cars that have them an they have no oil anywhere on there car.
Old 09-30-2006, 02:00 PM
reocamaro's Avatar
It probably isn't hooked up right (as much of what was initially hooked up was done wrong), I wonder how I could see if it's even switching at the right times.
Old 09-30-2006, 02:03 PM
yah i would like to no the same thing bro.
Old 09-30-2006, 02:05 PM
http://www.trtturbo.com/images/Chris_Firehawk_003.jpg
i found this at trt, you have to look really close but you can see how its hook up.
Old 09-30-2006, 02:11 PM
reocamaro's Avatar
Did your buy your turbo from TRT? I did and I bought my custon grind cam that I'm installing this week too. I can't wait to see my car when it's all said and done. Our setups are extremely similar except you have an m6 and I have an auto. Even our times are close. My best was 12.69 @ 119 and a 12.7 @ 120. And you make about 40 more ft.lbs of torque.
Old 09-30-2006, 02:18 PM
well i had my hook up right, but it still sprays oil at high boost, has any fix this problem an what did u do? could the pcv be bad, if so how do you tell if it is.
Old 09-30-2006, 03:01 PM
reocamaro's Avatar
If you look under the FI section you'll find more **** than you'll ever need to know about the PCV setup. I decided to put a check valve in , but I do remember reading how to check if your PCV is good. Wasn't looking for that information, so I just skipped over it. Sorry.
Old 09-30-2006, 03:43 PM
Dragframe's Avatar
and dont you hate it when you need it later and you cant find it? lol
Old 09-30-2006, 04:17 PM
stick a catch can between the valve cover and the switch valve...it will stop spitting oil at that point
Old 09-30-2006, 06:56 PM
let me ask you this, the wire going to the switch valve, is it supposta be a hot wire at any point, an when you turn the key on is it supposta to come on for a split second.
Old 09-30-2006, 08:13 PM
reocamaro's Avatar
That's a good question. And I'd be interested in knowing the answer to that.
Old 10-01-2006, 05:47 AM
still wanting know please, can anyone help me help now, help me, please someone help me
Old 10-01-2006, 12:10 PM
trtturbo's Avatar
The wire going to the switch valve is hot when you reach 1psi of boost. There is a pressure switch that is set at 1psi. When it sees 1psi, it will switch the switch valve and also turn the oil return pump on high.
