Pushrod Q - Will I be alright?
I purchased a camshaft kit from TSP with a 220/220 114lsa .581" cam and 7.4" hardened pushrods. I've also purchased a set of brand new LS6 heads, the one's they sold before the PRC line I guess.
Will I be O.K with this pushrod length, cam and head combination? I don't think I'll have a problem due to the small size of the cam...but figured I'd ask anyway. Don't want to F up my motor any more. Thanks!
Rick M.
Rick M.
Hey Rick, get a hold of a PR length checker and measure. They cost $20, or maybe borrow one from someone local. I'd hate to say you're OK with 7.40" and then have something bad happen.
I might be up at NED on Oct 13th and I could bring a PR checker and let you borrow it.
ahhh. Gotcha.
So. could I pick up a length checker locally? If not I'll probably just order one through a vendor and have it overnighted. Also, for the price of some new pushrods, wouldn't I be better off getting those versus buying $160 gaskets? I understand they can increase compression. But is it really worth it for my application? I do have a fairly mild set up. Thanks again guys! you all rock.
Rick M.
Rick M.
Originally Posted by PREDATOR-Z
If your heads are unmilled then run a .040 Cometic. That will make the 7.400 fit better.
Otherwise unmilled with stock gaskets, I would run 7.425.
I have installed Comp Cams 224/230, 0.581/.592, 114LSA using stock heads, stock gasket and stock length Comp Cam's pushrods. Have not started the engine yet. Is there anything to worry about?
Originally Posted by bluecamaroz28
Why are longer pushrods needed, with stock heads, stock gasket and just high lift camshaft?
Don't panic guys, 7.400 p-rods will work, they just will make your motor sound like a sewing machine (which a lot of poeple think it is normal). Longuer p-rods will get closer to original lifter preload and quieten that LSX down a bit.
