Fast 65# Injectors
Originally Posted by JMBLOWNWS6
59 psi
This is a N/A engine. I have fuel presure set at 40#.
On the dyno it goes up to 4000 rpm and wont go any higher.
Thanks again, John.
you dont need a pressure for them to opperate, they just wont flow as much fuel. At 40 PSI they will be 53.5#. The formula for this is: New rating= old rating x square rt. of new pressure/old pressure. Hope this makes sense.
Don't think that..
All of the FAST injs are rated at 45PSI. [Per their tech desk].The 65's are made by DELPHI.. They rate theirs @ 3 bars, [43.5PSI], as do most injector mfgrs, that are used in hipo applications.
Given they are rated at 65PPH @ 45psi, at 59PSI, they should flow 75.05#/hr.
I test alot of the DELPHI's and find they are very irratic at operating PSI over about 65PSI delta.
BTW, they are a low impedence inj....
Back to
Yep..
Originally Posted by JOHN LAWSON
I called Fast tech desk. I expect to make around 800 crank hp. They said 45 psi should be plenty
800 x .5
_________ = 58.8#/HR
8 x .85
Quick ?? How big is this engine to be putting out that much "steam" N/A??
Let'r rip!
Originally Posted by Old Geezer
The math shows the injs will be "good to go", at 800FWHP..
800 x .5
8 x .85
Let'r rip!
800 x .5
8 x .85
Let'r rip!
C5R Heads
Beck 100 MM Intake
Here is some pics.
http://www.dayton-fbody.com/DFBAbb/viewtopic.php?t=1692
