Fast 65# Injectors
Old Oct 8, 2006 | 03:22 AM
JOHN LAWSON's Avatar
Default Fast 65# Injectors
How much fuel presure will I need for these to operate corect?
Thanks, John.
Old Oct 8, 2006 | 03:57 AM
JMBLOWNWS6's Avatar
59 psi
Old Oct 8, 2006 | 11:28 AM
Originally Posted by JMBLOWNWS6
59 psi
Thanks, That might be my problem.
This is a N/A engine. I have fuel presure set at 40#.
On the dyno it goes up to 4000 rpm and wont go any higher.
Thanks again, John.
Old Oct 8, 2006 | 01:09 PM
67Ranger's Avatar
you dont need a pressure for them to opperate, they just wont flow as much fuel. At 40 PSI they will be 53.5#. The formula for this is: New rating= old rating x square rt. of new pressure/old pressure. Hope this makes sense.
Old Oct 9, 2006 | 02:17 PM
Old Geezer's Avatar
Question Don't think that..
these 65's are rated at 59PSI.
All of the FAST injs are rated at 45PSI. [Per their tech desk].The 65's are made by DELPHI.. They rate theirs @ 3 bars, [43.5PSI], as do most injector mfgrs, that are used in hipo applications.
Given they are rated at 65PPH @ 45psi, at 59PSI, they should flow 75.05#/hr.
I test alot of the DELPHI's and find they are very irratic at operating PSI over about 65PSI delta.
BTW, they are a low impedence inj....
Back to
Old Oct 9, 2006 | 04:57 PM
I called Fast tech desk. I expect to make around 800 crank hp. They said 45 psi should be plenty
Old Oct 10, 2006 | 08:42 AM
Old Geezer's Avatar
Thumbs up Yep..
The math shows the injs will be "good to go", at 800FWHP..
800 x .5
_________ = 58.8#/HR
8 x .85
Quick ?? How big is this engine to be putting out that much "steam" N/A??
Let'r rip!
Old Oct 10, 2006 | 02:06 PM
800 x .5
8 x .85
Let'r rip!
LS1 422 ci
C5R Heads
Beck 100 MM Intake
Here is some pics.
http://www.dayton-fbody.com/DFBAbb/viewtopic.php?t=1692
